xuraax Posted September 6 Share Posted September 6 I would like to use the mmc commands available in uboot on this board. I am able to boot properly in this mode and "help" properly lists all the commands available in this mode. On my board Armbian is running in EMMC. When I invoke "mmc" or the "mmcinfo" commands the system replies with the following error: Card did not respond to voltage select If I insert an Sdcard in the slot these two commands do respond properly which implies that uboot is seeing the Sdcard as default. Is there a way to redirect these commands to the EMMC? Regards 0 Quote Link to comment Share on other sites More sharing options...
