Rodman Posted September 6 Share Posted September 6 (edited) Armbianmonitor: https://paste.armbian.com/ejohosazaw Hello, I've been having some issues with the official CB1 image on github provided by BTT. Namely, I'm having CAN issues with bytes_invalid increasing during printing operation which is exacerbated once I add more than 1 CAN device. One of the recommendations was to try a newer kernel so I'm trying to migrate to Armbian. I have called out the appropriate overlays (MCP2515)and verified that they are loaded in the armbianEnv.txt file. However, I am not able to load up a Can network. I have created a file in /etc/systemd/network/80-can.network containing the below info. [Match] Name=can* [CAN] BitRate=1000000 I also ran dtc -s /proc/device-tree 2>/dev/null > foo.dts foo.dts Edited September 6 by Rodman Added foo.dts file 0 Quote Link to comment Share on other sites More sharing options...
JohnTheCoolingFan Posted September 7 Share Posted September 7 After changing the overlays, make sure to reboot the board. The device tree you sent shows mcp2515 as disabled. I've booted the current armbian image on my board, added just mcp2515 to the overlays, and the device tree shows mcp2515 as enabled. 0 Quote Link to comment Share on other sites More sharing options...
Solution JohnTheCoolingFan Posted September 7 Solution Share Posted September 7 From more testing on my end, I found out that the `light` overlay causes errors. Please remove it from the list, and the CAN should work. 0 Quote Link to comment Share on other sites More sharing options...
Rodman Posted September 7 Author Share Posted September 7 Looks like removing the "light" overlay does allow the CAN network to start up. Thanks for the help! Unfortunately, it appears that the bytes_invalid issue persists with this kernel as well. The hunt continues! 0 Quote Link to comment Share on other sites More sharing options...
JohnTheCoolingFan Posted September 7 Share Posted September 7 I've submitted a patch to github that fixes the `light` overlay: https://github.com/armbian/build/pull/7183 It would allow to use the light overlay, if needed. 0 Quote Link to comment Share on other sites More sharing options...
