Unable to Setup CAN Network
Go to solution Solved by JohnTheCoolingFan,
Posted (edited)
Hello,
I've been having some issues with the official CB1 image on github provided by BTT. Namely, I'm having CAN issues with bytes_invalid increasing during printing operation which is exacerbated once I add more than 1 CAN device.
One of the recommendations was to try a newer kernel so I'm trying to migrate to Armbian. I have called out the appropriate overlays (MCP2515)and verified that they are loaded in the armbianEnv.txt file. However, I am not able to load up a Can network. I have created a file in /etc/systemd/network/80-can.network containing the below info.
[Match]
Name=can*
[CAN]
BitRate=1000000
I also ran
dtc -s /proc/device-tree 2>/dev/null > foo.dts
foo.dts
Edited by Rodman
Added foo.dts file
After changing the overlays, make sure to reboot the board. The device tree you sent shows mcp2515 as disabled. I've booted the current armbian image on my board, added just mcp2515 to the overlays, and the device tree shows mcp2515 as enabled.
Looks like removing the "light" overlay does allow the CAN network to start up. Thanks for the help!
Unfortunately, it appears that the bytes_invalid issue persists with this kernel as well. The hunt continues!
@JohnTheCoolingFan Hey mate. Im using this firmware on CB1 also. I tried what you said above but its still defaulting to txqueuelenth to 10.
I can manually start can0 at the desired speed and queue length but doesnt persist after boot.
Sorry for the long delay.
I don't have experience with CAN networks, but a quick search found this gist, which uses systemd network and udev rules to set the txqueuelen: https://gist.github.com/Lauszus/733c4c4c6abacd19a0b5dad099fab172
You can change the device name match to just can0 instead of a wildcard if you want.
I've bought a few spi-to-can adapters to later test how this works myself, but if you can please try the linked method.
