GBEM Posted September 7, 2024 Posted September 7, 2024 I'm curious to experiment with LLMs on an RK3566 TV Box. I managed to build a working Debian disto for it, but wasn't able to locate any NPU support in the kernel configuration. Anyone know how to build such a kernel for the RK3566, with support for the inbuilt NPU, or preferably, how to add build a NPU kernel module that can be linked-in? Any hints, suggestion or links greatly appreciated. GBEM 👽 0 Quote
Laikulo Posted June 16 Posted June 16 (edited) If you are on a relatively recent kernel, the kernel probably already has support, but the default DTB has it disabled. This is from a bookworm nightly build for a radxa zero 3 ~$ grep rknpu /usr/lib/modules/6.1.115-vendor-rk35xx/modules.builtin kernel/drivers/rknpu/rknpu.ko However, it's disabled in the DTB by default $ cat /sys/firmware/devicetree/base/npu@fde40000/status disabled For the board that I am using, the vendor publises a DTO source that enables it at https://github.com/radxa-pkg/radxa-overlays/blob/main/arch/arm64/boot/dts/rockchip/overlays/rk3568-npu-enable.dts Which works well with armbian-add-overlay. Though you may need to make a similar overlay for your DTB if it is different enough. Note that the NPU in the 3566 and 3568 are interoperable. Edited June 16 by Laikulo formatting 0 Quote
