[Armbian build PR] - dt_makefile_patcher: fix dtbs with dot in filename
Description
We do not build dtbs with dot in filename because the current re match rule will ignore them. This fixes https://github.com/armbian/build/issues/7187
How Has This Been Tested?
Checklist:
Please delete options that are not relevant.
View the full article
