[Armbian build PR] - add new board armsom-cm5-io
Description
ArmSoM CM5 IO board is a board carrying SoM ArmSoM CM5, which has rk3576 soc and is compatible with raspberry's cm4 carrier board. Board info: https://docs.armsom.org/armsom-cm5-io Vendor device tree is already merged https://github.com/armbian/linux-rockchip/pull/215
How Has This Been Tested?
  • [ ] ./compile.sh BOARD=armsom-cm5-io BRANCH=vendor BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=noble KERNEL_GIT=shallow BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base
Checklist:
Please delete options that are not relevant.
View the full article
