RSS Bot Posted September 9, 2024 Posted September 9, 2024 Bumps peter-evans/create-pull-request from 6 to 7. Release notes Sourced from peter-evans/create-pull-request's releases. Create Pull Request v7.0.0 :sparkles: Now supports commit signing with bot-generated tokens! See "What's new" below. :writing_hand::robot: Behaviour changes Action input git-token has been renamed branch-token, to be more clear about its purpose. The branch-token is the token that the action will use to create and update the branch. The action now handles requests that have been rate-limited by GitHub. Requests hitting a primary rate limit will retry twice, for a total of three attempts. Requests hitting a secondary rate limit will not be retried. The pull-request-operation output now returns none when no operation was executed. Removed deprecated output environment variable PULL_REQUEST_NUMBER. Please use the pull-request-number action output instead. What's new The action can now sign commits as github-actions[bot] when using GITHUB_TOKEN, or your own bot when using GitHub App tokens. See commit signing for details. Action input draft now accepts a new value always-true. This will set the pull request to draft status when the pull request is updated, as well as on creation. A new action input maintainer-can-modify indicates whether maintainers can modify the pull request. The default is true, which retains the existing behaviour of the action. A new output pull-request-commits-verified returns true or false, indicating whether GitHub considers the signature of the branch's commits to be verified. What's Changed build(deps-dev): bump @types/node from 18.19.36 to 18.19.39 by @dependabot in peter-evans/create-pull-request#3000 build(deps-dev): bump ts-jest from 29.1.5 to 29.2.0 by @dependabot in peter-evans/create-pull-request#3008 build(deps-dev): bump prettier from 3.3.2 to 3.3.3 by @dependabot in peter-evans/create-pull-request#3018 build(deps-dev): bump ts-jest from 29.2.0 to 29.2.2 by @dependabot in peter-evans/create-pull-request#3019 build(deps-dev): bump eslint-plugin-prettier from 5.1.3 to 5.2.1 by @dependabot in peter-evans/create-pull-request#3035 build(deps-dev): bump @types/node from 18.19.39 to 18.19.41 by @dependabot in peter-evans/create-pull-request#3037 build(deps): bump undici from 6.19.2 to 6.19.4 by @dependabot in peter-evans/create-pull-request#3036 build(deps-dev): bump ts-jest from 29.2.2 to 29.2.3 by @dependabot in peter-evans/create-pull-request#3038 build(deps-dev): bump @types/node from 18.19.41 to 18.19.42 by @dependabot in peter-evans/create-pull-request#3070 build(deps): bump undici from 6.19.4 to 6.19.5 by @dependabot in peter-evans/create-pull-request#3086 build(deps-dev): bump @types/node from 18.19.42 to 18.19.43 by @dependabot in peter-evans/create-pull-request#3087 build(deps-dev): bump ts-jest from 29.2.3 to 29.2.4 by @dependabot in peter-evans/create-pull-request#3088 build(deps): bump undici from 6.19.5 to 6.19.7 by @dependabot in peter-evans/create-pull-request#3145 build(deps-dev): bump @types/node from 18.19.43 to 18.19.44 by @dependabot in peter-evans/create-pull-request#3144 Update distribution by @actions-bot in peter-evans/create-pull-request#3154 build(deps): bump undici from 6.19.7 to 6.19.8 by @dependabot in peter-evans/create-pull-request#3213 build(deps-dev): bump @types/node from 18.19.44 to 18.19.45 by @dependabot in peter-evans/create-pull-request#3214 Update distribution by @actions-bot in peter-evans/create-pull-request#3221 build(deps-dev): bump eslint-import-resolver-typescript from 3.6.1 to 3.6.3 by @dependabot in peter-evans/create-pull-request#3255 build(deps-dev): bump @types/node from 18.19.45 to 18.19.46 by @dependabot in peter-evans/create-pull-request#3254 build(deps-dev): bump ts-jest from 29.2.4 to 29.2.5 by @dependabot in peter-evans/create-pull-request#3256 v7 - signed commits by @peter-evans in peter-evans/create-pull-request#3057 New Contributors @rustycl0ck made their first contribution in peter-evans/create-pull-request#3057 Full Changelog: https://github.com/peter-evans/create-pull-request/compare/v6.1.0...v7.0.0 Create Pull Request v6.1.0 ✨ Adds pull-request-branch as an action output. What's Changed ... (truncated) Commits 8867c4a fix: handle ambiguous argument failure on diff stat (#3312) 6073f54 build(deps-dev): bump @typescript-eslint/eslint-plugin (#3291) 6d01b56 build(deps-dev): bump eslint-plugin-import from 2.29.1 to 2.30.0 (#3290) 25cf845 build(deps-dev): bump @typescript-eslint/parser from 7.17.0 to 7.18.0 (#3289) d87b980 build(deps-dev): bump @types/node from 18.19.46 to 18.19.48 (#3288) 119d131 build(deps): bump peter-evans/create-pull-request from 6 to 7 (#3283) 73e6230 docs: update readme c0348e8 ci: add v7 to workflow 4320041 feat: signed commits (v7) (#3057) 0c2a66f build(deps-dev): bump ts-jest from 29.2.4 to 29.2.5 (#3256) Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
