in using minimal armbian with network configuration through dhcpd, ifupdown, wpa_supplicant
systemd-networkd-wait-online failing to start during boot causing long boot time.
systemctl restart systemd-networkd-wait-online.service
causing an error
Job for systemd-networkd-wait-online.service failed because the control process exited with error code.
See "systemctl status systemd-networkd-wait-online.service" and "journalctl -xeu systemd-networkd-wait-online.service" for details.
Sep 10 22:48:17 orangepi5pro systemd-networkd-wait-online[457]: Timeout occurred while waiting for network connectivity.
Sep 10 22:48:17 orangepi5pro systemd[1]: systemd-networkd-wait-online.service: Main process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit systemd-networkd-wait-online.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Sep 10 22:48:17 orangepi5pro systemd[1]: systemd-networkd-wait-online.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit systemd-networkd-wait-online.service has entered the 'failed' state with result 'exit-code'.
Sep 10 22:48:17 orangepi5pro systemd[1]: Failed to start systemd-networkd-wait-online.service - Wait for Network to be Configured.
░░ Subject: A start job for unit systemd-networkd-wait-online.service has failed
░░ A start job for unit systemd-networkd-wait-online.service has finished with a failure.
░░ The job identifier is 116 and the job result is failed.
IDX LINK      TYPE     OPERATIONAL SETUP
  1 lo        loopback carrier     unmanaged
  2 enP4p65s0 ether    no-carrier  configuring
  3 can0      can      routable    unmanaged
  4 wlan0     wlan     routable    unmanaged
