RSS Bot Posted September 11, 2024 Posted September 11, 2024 Description ArmSoM CM5 is a rk3576 SoM compitable with raspberrypi CM4 carrier board. And CM5 IO is the official carrier board from ArmSoM. More info: https://docs.armsom.org/armsom-cm5 https://docs.armsom.org/armsom-cm5-io How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] ./compile.sh BOARD=armsom-cm5-io BRANCH=vendor BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=noble KERNEL_GIT=shallow BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base [x] Tested with emmc and sdcard boot. Notice that sd card can't boot with a blank emmc, at least idbloader.img in emmc is necessary. Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
