RSS Bot Posted September 12, 2024 Posted September 12, 2024 Description Context systemd's cloud-init.target and armbian-firstrun.service will be started concurrently (both are wanted by multi-user.target). Both will try to create SSH host keys by default: armbian-firstrun will always delete SSH host keys and then generate new ones cloud-init.target (by default) will always delete SSH host keys and then generate new ones. Problem When one must run armbian-firstrun and cloud-init, there is no deterministic ordering between the 2 files execution and therefore no one can guarantee which will be last to setup OpenSSH host keys. In my current scenario, host keys are explicitly setup in cloud-init and I would expect armbian-firstrun to not delete keys + no ssh host key generation. Implemented Solution armbian-firstrun support user defined config to optionally regenerate SSH host keys: no: no ssh key deleted + no ssh host key generated. Allow cloud-init to take over this behaviour deterministically. yes (or undefined): ssh host key deleted + generated (compatibility: current armbian behaviour) Documentation summary for feature / change If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer: [x] short description armbian-firstrun: Optionally skip OpenSSH host key regeneration [x] summary To skip armbian-firstrun's OpenSSH host key deletion + regeneration (eg: to let cloud-init set the SSH host keys), then define OPENSSHD_REGENERATE_HOST_KEYS=no in the /path/to/userpatches/config-*.conf file used by ./compile.sh to build the image. [ ] example of usage See above How Has This Been Tested? [ ] qemu-x86 board: build with OPENSSHD_REGENERATE_HOST_KEYS=no and expect armbian-firstrun to not regenerate ssh host keys [ ] [Test B](qemu-x86 board: build without OPENSSHD_REGENERATE_HOST_KEYS set and expect armbian-firstrun to regenerate ssh host keys Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
