MXQPRO 4K 5G fake S905 8GB +128GB real RK3128 1GB + 4GB
cpu: RK3128
ram: 4 x H5TQ2G43BFR  2Gbit (512M x 4) = 1GB
emmc: THGBMDG5  32Gbit = 4GB
Wifi: SV6158
heatsink also seemed fake, plastic, was not cool to touch like metal, removed to check cpu. cpu was not listed, but S905 was in photo. I claimed refund for counterfeit goods. I Expected it not to be S905, if it was a RK322X i would have kept it for armbian but RK3128 is worthless.
Edited by firepower
DDR Version 2.06 20170316
In
1A1A1C1C   3
DDR3
282C1C1C   3
35351C1C   3
Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
mach:2
OUT
Boot1 Release Time: 2017-06-12, version: 2.40
ChipType = 0xa, 1384
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
FwPartO�*V�k%���=0 20
StorageInit ok = 113376
SEC = 1
SecureInit 4 114844
Code check OK! theLoader 0x60000000, 168321
hdr 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
U-Boot 2014.10-RK3128-06-g829baaa (Apr 19 2024 - 09:54:01)
CPU: rk3128
cpu version = 0
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 594000000HZ
    ddr pll = 600000000HZ
    codec pll = 400000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000060000000(0000000040000000)
128 MiB
GIC CPU mask = 0x00000001
rk dma pl330 version: 1.4
remotectl v0.1
pwm freq=0xb�*V�k%��� = 0 20
SdmmcInit = 2 0
storage init OK!
Using default environment
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
can't find dts node for fixed
No pmic detect.
power hold: bank-16777215 pin-255, active level-0
Secure Boot Mode: 0x1
SecureBootEn = 1, SecureBootLock = 1
#Boot ver: 2024-04-19#2.40
empty serial no.
normal boot.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
can't find power_ctr node for lcdc0
can't find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
Hdmi Devices Not Exist.
SCREEN_TVOUT
rk3036_tve_init:use default config g_tve_pos = 1
read logo on state from dts [1]
no fuel gauge found
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
Secure Boot state: 1
kernel   @ 0x62000000 (0x0068db20)
ramdisk  @ 0x65bf0000 (0x00167f20)
bootrk: do_bootm_linux...
   Loading Device Tree to 65600000, end 65617398 ... OK
Add bank:0000000060000000, 0000000040000000
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.104 (txcz@txcz-host2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Apr 19 09:45:47 CST 2024
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
[    0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x9dc00000, offset:0x00000000
[    0.000000] hdmi init vic is 1704292188
[    0.000000] cvbs init tve.format is 1
[    0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x9dc00000 for uboot logo
[    0.000000] rockchip_ion_reserve
[    0.000000] ion heap(cma): base(0) size(800000) align(0)
[    0.000000] ion heap(vmalloc): base(0) size(0) align(0)
[    0.000000] cma: CMA: reserved 8 MiB at 9d400000
[    0.000000] ion_reserve: cma reserved base 9d400000 size 8388608
[    0.000000] cma: CMA: reserved 16 MiB at 7f000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1672000 s13440 r8192 d15232 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 261120
[    0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=disabled androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00006000@0x00010000(kernel),0x00006000@0x00016000(boot),0x00010000@0x0001C000(recovery),0x00020000@0x0002C000(backup),0x00040000@0x0004C000(cache),0x00008000@0x0008C000(metadata),0x00002000@0x00094000(kpanic),0x00200000@0x00096000(system),0x00020000@0x00296000(radical_update),-@0x002B6000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2024-04-19_09:54:01 hdmi.vic=1704292188 tve.format=1 SecureBootCheckOk=1
[    0.000000] rockchip jtag enabled
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 2097152 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 964088k/964088k available, 84488k reserved, 483328K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0bc6f5c   (12028 kB)
[    0.000000]       .init : 0xc0bc7000 - 0xc0c26480   ( 382 kB)
[    0.000000]       .data : 0xc0c28000 - 0xc0d0c3a0   ( 913 kB)
[    0.000000]        .bss : 0xc0d0c3a0 - 0xc0e2c95c   (1154 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
