RSS Bot Posted September 17, 2024 Posted September 17, 2024 Description When m.2 wifi module has a usb bluetooth, it can get detected but has error when loading driver: rejected 1 configuration due to insufficient available bus power This commit will add a udev rule setting all usb device attr bConfigurationValue to 1 if it has a null value, which will fix the bluetooth usb device. Hint from https://community.nxp.com/t5/i-MX-Processors/USB-1-0-disable-100mA-current-limit-permanently/td-p/1600252 How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] ./compile.sh BOARD=armsom-w3 BRANCH=vendor BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=noble KERNEL_GIT=shallow BUILD_DESKTOP=yes DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base ENABLE_EXTENSIONS="mesa-vpu" Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
