RSS Bot Posted September 16, 2024 Posted September 16, 2024 Bumps setuptools from 74.1.0 to 75.1.0. Changelog Sourced from setuptools's changelog. v75.1.0 Features Deprecated bdist_wheel.universal configuration. (#4617) Bugfixes Removed reference to upload_docs module in entry points. (#4650) v75.0.0 Features Declare also the dependencies used by distutils (adds jaraco.collections). Deprecations and Removals Removed upload_docs command. (#2971) pypa/distutils#294#4649) v74.1.3 Bugfixes Fix cross-platform compilation using distutils._msvccompiler.MSVCCompiler -- by :user:saschanaz and :user:Avasam (#4648) v74.1.2 Bugfixes Fixed TypeError in sdist filelist processing by adding support for pathlib Paths for the build_base. (#4615) Removed degraded and deprecated test_integration (easy_install) from the test suite. (#4632) ... (truncated) Commits 3106af0 Bump version: 75.0.0 → 75.1.0 37c3d27 Removed reference to upload_docs module in entry points. 9fb53fd Merge pull request #4617 from abravalheri/issue-4612 cd3ba7d Merge pull request #4644 from DimitriPapadopoulos/codespell 5e27b2a Bump version: 74.1.3 → 75.0.0 af9e245 Merge pull request #4649 from pypa/feature/distutils-7283751 f15861e Add news fragment. ce01828 Merge https://github.com/pypa/distutils into feature/distutils-7283751 378984e Remove news fragments, not useful here. ffdf0bd Merge tag 'v74.1.3' Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
