RSS Bot Posted September 16, 2024 Posted September 16, 2024 Bumps dtschema from 2024.5 to 2024.9. Commits c51125d schemas: i2c: add generic interrupt name for I2C controllers 285f991 schemas: i2c: clean up interrupt descriptions for I2C targets 74bc7ea schemas: i2c: reword descriptions for inclusive language 5270b95 dt-validate: Support multiple schema id matches 449b457 schemas: property-units: Exclude some non-conforming properties 8f5303c meta-schemas: Disable checks on non-conformant unit suffix properties e5d88ac dtb: Fix 'interrupt-map' decoding for single entry 69c4839 validator: Decend allOf/anyOf/oneOf keywords when extracting properties f13c181 dtb: Handle multiple types differing in sign c00f747 dtb: Handle multiple types for 'dma-masters' Additional commits viewable in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
