RSS Bot Posted September 15, 2024 Posted September 15, 2024 Description add patch which add to vendor u-boot support for sata boot from m.2 e-key(switch m.2 to sata and extra sata defconfig) added additional u-boot target too build the additional u-boot image with these changes the patch can be removed if this pull request for vendor u-boot for rock-3a is accepted https://github.com/radxa/u-boot/pull/95 Documentation summary for feature / change rock-3a:add u-boot image for sata boot on m.2 e.key for sata boot the rkspi_loader_sata.img has to be flashed on spi flash (use dd or flashcp) flash armbian image to sata device with dd (or ifd3f/caligula , etcher cli ) mount armbian boot partition on sata device and add rock-3a-sata too useroverlay poweroff and remove sdcard( or emmc ) to boot from sata armbian install doesnt work because u-boot needs extra vfat boot partition which armbian install doesnt create only single partition How Has This Been Tested? compiled with github ci https://github.com/pykpkg47/armbian-image-build/actions/runs/10874313933/job/30171463631 compile log https://paste.armbian.com/fasuhomeri artifacts : https://github.com/pykpkg47/armbian-image-build/releases/tag/24.8.3 tested on rock-3a u-boots detects sata ssd connected via adapter to m.2 e-key and boots kernel from it Checklist: [x ] My code follows the style guidelines of this project [x ] I have performed a self-review of my own code [ x] My changes generate no new warnings View the full article
