Blocking a package from installation (WireGuard in my case)
I had some issues regarding WireGuard that are solved now. Since my armbian release already contains wireguard I have no need to install it. However I wanted to prevent any future mistake rendering my installation unbootable. So after some searching and experimenting I did the following:
In order to block a package a file must be created in /etc/apt/preferences.d/ , in my case I called it wireguard
$ sudo tee /etc/apt/preferences.d/wireguard &>/dev/null <<EOF
Package: wireguard
Pin: release *
Pin-Priority: -1
EOF
This is what it looks like now when trying to install the package:
$ sudo apt install wireguard
Reading package lists... Done
Building dependency tree... Done
Package wireguard is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'wireguard' has no installation candidate
Unfortunately this still gave me the option to autoremove wireguard-tools
sudo apt autoremove
The following packages will be REMOVED:
  wireguard-tools
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 366 kB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
So I marked the wireguard-tools package as manual because I still need it:
$ sudo apt-mark manual wireguard-tools
wireguard-tools set to manually installed.
And now it does not bother me with "unneeded" packages warning when using apt :
$ sudo apt autoremove
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Yay!
