Horst Posted 8 hours ago Share Posted 8 hours ago Hello, I'm a lay user, I don't know much about Armbian and networks - On my network I have a router whose default DNS is set to point to an OrangePI 3 lts with Armbian 23.02, where I installed AdGuard (v0.107.52) and created my rules to filter advertisements through URLs that I access through the web browser of any device. It works almost 100% as I would like - I use a NO-IP DDNS on the router to access the surveillance DVR and I can see the cameras fine on my smartphone. However, when there is a power outage and then it comes back on, there is often some kind of synchronization failure between the router and the OrangePI to access the cameras. So I need to restart the Orangepi to be able to view them remotely again. I believe it could be something related to the free and dynamic DDNS, or because I needed to disable the router's DHCP and transfer this function to the OrangePI (so that the network device logs could work correctly through AdGuard). I would like to know: 1) Is there a way to program the OrangePI to restart itself every X hours? What program do I need to install (with a tutorial if possible) and how can I configure a script for this? I tried to find something within armbian-config, I searched on Google, but I couldn't find exactly what I was looking for. So I want to test if this would solve my problem. 2) What is the easiest way to access the OrangePI system files from Windows? Is it via FTP? I use PuTTY for remote access, but I don't know much more about it. Thank you 0 Quote Link to comment Share on other sites More sharing options...
