Net-ISP-Balance - Load-balance your Internet connection across two or more ISPs for improved bandwidth and reliability
I followed the steps outlined in the instructions, and they worked very well for me with (10 ISPs) 4G dongles using PPP connections.
TV Box Model tested: MXQ Pro 4K, 5G (H3 Allwinner), ISO: Sunvell 69. I started with Debian 10 and later upgraded to Debian 11.  I also use a second USB 3.0 LAN card, as well as the dongles connected through a USB hub with an independent power supply.
For more information, you can check the following resources:
Installing the Perl dependencies took some time.
Net-ISP-Balance Documentation
https://lstein.github.io/Net-ISP-Balance/
Net-ISP-Balance GitHub Repository
https://github.com/lstein/Net-ISP-Balance
Thanks to Lincoln D. Stein
Edited by Eugenio Eugenio
