Probably the easiest and fastest way to set up an Ubuntu Xenial build environment (needed by the armbian build scripts) is using a chroot jail. This thread should be a quick copy paste "tutorial" to create your own chroot jail and on an Debian based linux installation.
1.) Install debootstrap
$ sudo apt install debootstrap
2.) Chreate chroot jail using debootstrap
$ sudo debootstrap --variant=buildd --arch=amd64 xenial ./system/ http://archive.ubuntu.com/ubuntu/
3.) Mount your local system into the chroot
$ for f in dev dev/pts proc sys ; do sudo mount -o bind /$f ./system/$f ; done
4.) Mount resolv.conf from host system into chroot
$ sudo mount --bind /etc/resolv.conf ./system/etc/resolv.conf
5.) Enter the chroot and install some important packages
$ sudo chroot ./system
$ apt install -y sudo nano git
6.) Add universe to your chroots repo list (needed by the build scripts)
$ sudo nano /etc/apt/sources.list
change from:
deb http://archive.ubuntu.com/ubuntu xenial main
to:
deb http://archive.ubuntu.com/ubuntu xenial main universe
then:
$ sudo apt update
7.) Download and start build script in root users home directory
$ cd
$ git clone https://github.com/armbian/build
$ cd build
$ service apt-cacher-ng start
( $ export EXPERT=yes )
$ ./compile.sh
Now you can start building your images from source :)
I know this is not rocket science, but I think this might help some people getting into Armbian!
