SuperMaximus Posted October 7, 2024 Posted October 7, 2024 (edited) Armbianmonitor: https://paste.armbian.com/obihohuzuf Hi! When I try to access PWM via procedure described here https://tinker-board.asus.com/forum/index.php?/topic/15132-direct-gpio-access/ I see that Quote pwmchip2 Expand & Quote pwmchip3 Expand are not present (although they should be) I can see pwmchip0, but I don't understand what GPIO it is. Following ASUS docs from GitHub https://github.com/TinkerBoard/TinkerBoard/wiki/User-Guide#gpio-config-table-for-tinker-board-s--tinker-board-s-r20 GPIO32 and GPIO33 should be here: PWM:/sys/class/pwm/pwmchip3 and PWM:/sys/class/pwm/pwmchip2 But those directories are not present. root@tinkerboard:~# ls -la /sys/class/pwm/ total 0 drwxr-xr-x 2 root root 0 Oct 7 11:47 . drwxr-xr-x 65 root root 0 Jan 1 1970 .. lrwxrwxrwx 1 root root 0 Oct 7 11:47 pwmchip0 -> ../../devices/platform/ff680000.pwm/pwm/pwmchip0 My Armbian Env is: verbosity=0 bootlogo=true console=serial overlay_prefix=rockchip overlays=i2c1 i2c4 spi2 spidev2 uart1 uart2 rootdev=UUID=7a71009a-a5f6-439f-a2d3-38574c1ea09b rootfstype=ext4 extraargs=vt.global_cursor_default=0 quiet splash plymouth.ignore-serial-consoles systemd.unified_cgroup_hierarchy=0 stdout=serial usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Edited October 7, 2024 by SuperMaximus Added info 0 Quote
jock Posted October 13, 2024 Posted October 13, 2024 Unfortunately I don't have a Tinkerboard S R2.0 but a Tinkerboard S R1.0. I took a look into the device trees and in fact I have the confirmation: for the Tinkerboard (all versions) only the pwm0 is enabled. pwm1, 2 and 3 are disabled. If you're still interested, I can provide the necessary device tree overlays to enable them selectively. 0 Quote
SuperMaximus Posted October 13, 2024 Author Posted October 13, 2024 @jock I would be grateful for your help! I want to control the Waveshare 7" HDMI LCD screen brightness via this PWM. 0 Quote
jock Posted October 13, 2024 Posted October 13, 2024 Here you get the pwm1, 2 and 3 overlays. Put them in /boot/dtb/rockchip/overlay directory and enable those you need in /boot/armbianEnv.txt or via armbian-config and you should get the pwm devices. rockchip-pwm1.dtboFetching info... rockchip-pwm2.dtboFetching info... rockchip-pwm3.dtboFetching info... 0 Quote
SuperMaximus Posted October 13, 2024 Author Posted October 13, 2024 Thanks for your recommendation. I followed it and added pwm1, pwm2, pwm3 to my armbianEnv verbosity=0 bootlogo=true console=serial overlay_prefix=rockchip overlays=i2c1 i2c4 spi2 spidev2 uart1 uart2 pwm1 pwm2 pwm3 rootdev=UUID=7a71009a-a5f6-439f-a2d3-38574c1ea09b rootfstype=ext4 extraargs=vt.global_cursor_default=0 quiet splash plymouth.ignore-serial-consoles systemd.unified_cgroup_hierarchy=0 stdout=serial usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u And now my Tinkerboard can't boot at all. I can't even connect via SSH. Is there any way out of it? Thanks! 0 Quote
jock Posted October 13, 2024 Posted October 13, 2024 @SuperMaximus oh, that's weird, sorry for the inconvenience! You should be able to attach an usb cable to the USB micro OTG port and then to a computer: the tinkerboard will appear as a mass storage device and you should be able to revert the changes. By the way, always enable only the overlay you need. I double checked and to use pwm2 or pwm3 ,you need to disable uart2 because some pins are muxed. Anyway I see something wrong in the device tree for the tinkerboard: all 4 uarts are enabled in the base device tree, thus having the overlays to enable is not useful and, moreover, uart2 should be the debug uart which is not a good idea to disable. I need to investigate a bit in this, but I hope you will be able at least to restore functionality of the board. 0 Quote
jock Posted October 14, 2024 Posted October 14, 2024 @SuperMaximus I just double checked on a pristine armbian installation on my tinkerboard and enabling pwm1, pwm2 and pwm3 does not incur in any inconvenience. All the 4 pwms are available in my case: root@tinkerboard:/sys/class/pwm# ls -lah total 0 drwxr-xr-x 2 root root 0 Oct 14 12:26 . drwxr-xr-x 66 root root 0 Oct 14 12:26 .. lrwxrwxrwx 1 root root 0 Oct 14 12:26 pwmchip0 -> ../../devices/platform/ff680000.pwm/pwm/pwmchip0 lrwxrwxrwx 1 root root 0 Oct 14 12:26 pwmchip1 -> ../../devices/platform/ff680010.pwm/pwm/pwmchip1 lrwxrwxrwx 1 root root 0 Oct 14 12:26 pwmchip2 -> ../../devices/platform/ff680020.pwm/pwm/pwmchip2 lrwxrwxrwx 1 root root 0 Oct 14 12:26 pwmchip3 -> ../../devices/platform/ff680030.pwm/pwm/pwmchip3 0 Quote
