Screwed-up my Wi-Fi client configuration
Go to solution Solved by mvuille,
I have Armbian 24.8.4 running on my CubieTruck.
I wanted to experiment with running an access point on it, and was able to configure and run hostapd to do so.
But now I want it to be a Wi-Fi client again and it appears that I royally screwed something up while playing with hostapd.
When I run armbian-config and select the Network option, nothing about Wi-Fi shows up any more.
Any suggestions where to start to get things back to how they were out-of-the-box? A reinstall is not an option.
  • Solution
Moderators: you can delete this thread
I ended up comparing my /etc directory tree with a backup and selectively restoring the files to their previous state.
After a reboot, things are thankfully back to normal.
