Hello all. I am following the template to write this post and I will add more details as well. My first ever message (here) was in the "Amlogic CPU Boxes" section.
TV Box Name: T95 Max+ (Plus)
CPU: S905x3
Armbian build file name: Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11.img.xz
DTB file used: /dtb-6.1.11-meson64/amlogic/meson-sm1-x96-air.dtb
Kernel Version: 6.1.11
Distribution Installed: jammy (Ubuntu)
Working Ethernet: Yes
Max Ethernet Speed that works: 100 Mbps
Does wifi work: No
Does bluetooth work: No
Does HDMI audio work: No
Additional Comments (provide any additional information you feel is important): Read below ...
I ran these commands to disable some features that could break the system or cause the system to not boot. This is from my experience of installing the system twice.
sudo apt-mark hold linux-image-current-meson64 armbian-bsp-cli-aml-s9xx-box armbian-firmware
sudo apt-mark hold linux-dtb-current-meson64 linux-u-boot-aml-s9xx-box-current
sudo systemctl disable --now systemd-networkd-wait-online.service
sudo systemctl disable --now unattended-upgrades
I wanted to get sound out of the box. So, I purchased a generic USB audio dongle from Aliexpress for $3 USD. (see attached photo). The USB audio device is described in Linux as a Texas Instruments PCM2902 Audio Codec (USB PnP Sound Device device 0 USB Audio), and when you run “lsusb” you will see the id numbers 08bb:2902.  I updated the databases for repositories by running “sudo apt update -y” and installed necessary packages to support the USB audio device and to use the XFCE4 graphical desktop. Here are the commands I ran for XFCE4 and for some additional nice bits:
sudo apt update -y;
sudo apt install -y xfdesktop4 xfce4 xfce4-power-manager xfce4-goodies xinit xdm xorg xserver-xorg;
sudo apt install -y arandr greybird-gtk-theme numix-gtk-theme numix-icon-theme epiphany-browser;
sudo apt install -y elementary-xfce-icon-theme xscreensaver xscreensaver-data xcvt firefox mesa-utils;
sudo apt install -y gvfs gvfs-fuse gvfs-common xubuntu-icon-theme at-spi2-core smplayer;
sudo apt install -y alsa-base alsa-oss alsa-tools alsa-utils alsamixergui pulseaudio pavucontrol pavumeter;
Edit the file /etc/modules with the “nano” command and write “snd-usb-audio” at the end of the file. Also, edit the file /etc/modprobe.d/alsa-base.conf and change a few things, but make a backup copy first:
sudo cp /etc/modprobe.d/alsa-base.conf  ~/alsa-base.conf.backup
Put a # symbol in front of every “options snd-usb-audio index=-2” that you see in /etc/modprobe.d/alsa-base.conf . I found two of them. Add these two lines of text to the bottom of /etc/modprobe.d/alsa-base.conf .
alias snd-card-0 snd-usb-audio
options snd-usb-audio index=0
Make sure that you are in the 'audio' group. Run the “usermod” command against a regular user (not root) that you want to use often. And reboot.
sudo usermod -a G audio {username here}
sudo reboot
After reboot, the graphical X Display Manager (xdm) should greet you with a simple gray prompt and you can login to XFCE4. You should see a red LED light blinking on the USB audio dongle. You may want to change the display resolution to 1280x720 or 1920x1080 (whichever is available to you) by clicking on the panel (start menu), Applications, Settings, and Display. The Arandr tool in Settings can also help you adjust the display resolution. Open the volume control program by clicking on the panel Applications, Multimedia, PulseAudio Volume Control. Click the Configuration tab at the far right of the volume control and change the profile to Analog Stereo. * Important – now connect a headset, earphone, or amplifier to the 3.5mm (⅛’’) black 🎧 receptacle on the USB audio dongle and play some sounds, music or youtube.
Edited by Pita Bread
add text
T95 Max+ (plus), 4 GB RAM / 32 GB ROM, S905×3
I successfully installed the system by following this guide by @Krypton and I updated it using sudo update -y && sudo upgrade -y but keeping kernel 6.1.11. The stereo sound is working fine through the cheap USB audio dongle. I installed pi-apps.io and installed some applications like Brave and PPSSPP emulator via pi-apps. I thank everyone here for the great guides, tips, files, and overall work done.
Update: sadness 😢.... and then happiness.
Yesterday, there were several severe thunderstorms and the electrical power in the home fluctuated a few times and afterwards completely got knocked out. (now fast-forward to the future, hours later). After power was restored by the utility company, this tv box powered on and gave a 1080p signal, would not boot but just had a black blank screen. I tried to boot Armbian from a fresh SD memory card in the TF slot and a from fresh USB flash drive in the USB 3.0 port but that didn't work either. I researched a lot, and managed to recover the TV box by using an img file of the factory stock Android. I will soon write a tutorial about what I've done and you can find it under another section of forum.
https://forum.armbian.com/forum/191-reviews-tutorials/
I can confirm that the T95 Max+ (Plus) is booting under the mentioned limitations (no WiFi, no Bluetooth, 100 Mbps) using the Server image Armbian Linux 6.6 Ubuntu 24.04 (Noble). I haven't tested installing to emmc, though.
CPU: S905x3
Armbian build file name: Armbian_community_25.2.0-trunk.160_Aml-s9xx-box_noble_current_6.6.65.img
DTB file used: /dtb/amlogic/meson-sm1-x96-air.dtb or /dtb/amlogic/meson-sm1-sei610.dtb
Kernel Version: 6.6.65
Distribution Installed: Noble (Ubuntu)
Does wifi work: No
I had to rename u-boot-s905x3 to u-boot.ext to boot successfully.
apt update && apt upgrade worked fine after installation at the time of 12/18/2024. However, it may still be advisable to freeze the packages mentioned in the original post.
/dtb/amlogic/meson-sm1-x96-air-gbit.dtb did not work (no Ethernet at all).
On 6/9/2025 at 8:15 AM, Offeacy61 said:
If you have a chance, tell me later whether you managed to set up Wi-Fi via a USB adapter or in another way. And I wonder if you tried other window environments besides XFCE? LXQt, for example?
Hello. Regarding a tv box, I briefly tried to connect a Realtek 8188 USB wifi adapter and get it working, but I quickly quit trying because there wasn't any appropriate firmware in Armbian or there was some other technical problem, and I didn't know to solve the problem. I know for certain that wifi adapter works in Linux, for example on a PC and in EmuElec.
I tried only XFCE4. But yes, I can recommend LXDE  and LXQt as an alternative to XFCE4 because they are lighter. ☺
edit text
Regarding USB audio - an excellent solution, I didn't even know that it was so easy to bypass the lack of built-in sound. I will try with a similar adapter.
I updated my guide to include the newer "pipewire" audio system software. LINK HERE. I am curious to know if you got sound working on your tv box, and how you did it. Also, what tv box are you using these days?
