Pita Bread Posted November 5, 2024 Posted November 5, 2024 After initially and successfully booting Armbian 23 jammy from an SD memory card in the TF slot or from a USB flash device in the blue 3.0 port, I had installed Armbian using the /root/install-aml.sh, removed the SD card/USB flash and rebooted Armbian easy peasy. It worked fine for a while. My thread about it is here at this link. But it got bricked, seemingly by itself after a power failure in the home. I managed to recover it with an image of Android, however, all of Armbian was deleted (and no backup either haha 😉). Here is a tutorial to recover this box and the steps may also work for other tv boxes that have the S905x / S905x2 / S905x3 chip. Download Amlogic Burn Card Maker v2.0.3 (not other versions) from Here or Here. Download stock android firmware T95MAXplus-X3-9.0-2GB4GB-6330-0720-20200616-Android.rar from Here or the same firmware but as img a file from MEGA Unpack the archive file in 7zip, if you have the rar file. But there is no unpacking to do if you have the img file. Insert a new good micro-SD memory card into the SD card adapter, and plug it into your PC - be sure there is only one single partition on the SD memory card formatted as FAT32 Run the 'Burn_Card_Maker.exe' executable file. Make sure it is version 2.0.3 Change language to English if it is not already in that: - Click on the Chinese menu (or garbled text menu) in the upper-left corner, and choose the second option. - Dialog screen appears and now simply select 'English Version' and click OK button. Select your SD memory card drive letter under 'Choose Disk:' - you may need to use Disk Management in Windows and apply a drive a letter to the SD memory card. Check mark the Yes box on under 'To Partition and Format' or tick the box 'Formatting SD card' - a new menu pane will popup. follow through and format the SD memory card. Check mark the Yes box on under the Normal SD bootloader for Erase Bootlooader Check mark the Yes box on under the Erase Flash for Normal Flashing Do NOT check mark the Yes on (click to Uncheck it) under 'reboot'. Click 'Open' button under 'Select Burn Package f:' and select the factory stock Android file T95MAXplus-X3-9.0-2GB4GB-6330-0720-20200616.img - make sure there are no spaces in the file name of the img Last step in Burn_Card_Maker: Press 'Make' button and wait to finish. Go to the TV box. Disconnect the power cable from the tv box device. Then insert the micro SD memory card in your tv box device and power on the device. If it didn't boot at all, the you may need to use the toothpick method. Disconnect power cable again. Put a toothpick into the audio jack, press and hold the reset button while you insert the power cable. The tv box will enter into recovery and the firmware will be flashed automatically. Be patient and wait up to 10 minutes. After the TV BOX fully starts, remove the micro SD Card. and the update will completed. The T95 Max (whatever it is) graphic logo will appear and stock Android 9 will start. 0 Quote
Tiago Santos Posted December 4, 2024 Posted December 4, 2024 Thx for sharing this tutorial 🥳 After The update, i can flash again The Slimbox rom ? Thx 😊👏🏻 1 Quote
Pita Bread Posted December 7, 2024 Author Posted December 7, 2024 (edited) Hello. You're welcome. My instructions were not for an 'update' but were for recovering a bricked tv box. I am not familiar with the details of Slimbox but hmm yes I suppose you can try to flash Slimbox (img?). Also, a few stock android files and Slimbox files for this tv box are on The Internet Archive at this link. If that website is blocked or downloading from that site is very slow, then use to a VPN service such as Nord or Surfshark and connect to a USA server. Edited December 7, 2024 by Pita Bread add text and link 0 Quote
sdavides Posted April 2, 2025 Posted April 2, 2025 Thankyou in my case TMAX 95+ China X3-9.0-2GB4GB-6330-0720-191119_1 https://www.mediafire.com/file/6ndvrg9ze0v6eww/X3-9.0-2GB4GB-6330-0720-191119_1.img/file 1 Quote
Pita Bread Posted April 24, 2025 Author Posted April 24, 2025 (edited) @sdavides You're welcome. I am glad you recovered your tv box 😀. Thanks for the link to your firmware file. But the link with "/file" did not work. I removed "/file" and this link works https://www.mediafire.com/file/6ndvrg9ze0v6eww/X3-9.0-2GB4GB-6330-0720-191119_1.img I will download the firmware file and make a backup of it on Archive.org web site. Please upload a photo 📷 of your tv TMAX 95 China tv box. Thanks. Cheers matey. Edited April 24, 2025 by Pita Bread 0 Quote
