splite Posted July 13, 2017 Posted July 13, 2017 Hello, I try to use DBus within the chroot and I got this issue : Failed to create bus connection The command used was : hostnamectl set-hostname device_name Systemd does not seems to work within the chroot, do you have any workaround ? Thanks, Florian
splite Posted July 13, 2017 Author Posted July 13, 2017 From what I have read, there is no way to use systemd in a chroot. This is quite annoying when it comes to build customization... chroot command could be swaped for systemd-nspawn in the Armbian build framework, does anybody tried this before ?
