eselarm Posted November 14, 2024 Posted November 14, 2024 qemu-system-aarch64 -M virt -cpu host -enable-kvm ... only works reliably when 1 CPU core ( -smp 1). When a VM has 2 cores, it randomly worked I experienced. If virt-manager pick 2 equal cores, VM UEFI/BIOS/kernel runs OK, but if a Cortex-A76 and Cortex-A55, all sorts of exceptions are shown or just lockup 2x or 1x 100% usage. In order to still be able to use KVM, start qemu-system-aarch64 as follows: taskset --cpu-list 4-7 qemu-system-aarch64 -M virt -cpu host -enable-kvm -smp 4 ... or taskset --cpu-list 0-3 qemu-system-aarch64 -M virt -cpu host -enable-kvm -smp 4 ... Mainline kernel 6.8.x or later does not have this problem. It can transparently use all 8 cores. Userspace is Debian Bookworm based. 0 Quote
eselarm Posted December 6, 2024 Author Posted December 6, 2024 Besides the manual CLI running of VMs with tasksel, there is also a good/acceptable way-of-working when using virt-manager/libvirt/virsh. Problem is already old I see, also the workaround here: So in my case on a NanoPi-R6C, that I just did upgrade, so got kernels: -rw-r--r-- 1 root root 33792512 Dec 5 18:28 vmlinuz-6.12.2-current-rockchip-rk3588 -rw-r--r-- 1 root root 39705088 Dec 1 18:38 vmlinuz-6.1.84-vendor-rk35xx I replaced: <vcpu placement="static">2</vcpu> with: <vcpu placement='static' cpuset='2-3'>2</vcpu> meaning now my home automation VM runs on 2x Cortex-A55 and I rebooted using the 6.1.84-vendor-rk35xx kernel. So far so good. This is great as I want also to do some video transcoding HEVC->H264 in the backgound (live) and hopefully also RKNPU experiments. 0 Quote
