Lorenzo Gentile Posted November 17 Posted November 17 I am trying to build a kernel module on latest tinkerboard Armbian release: uname -a Linux tinkerboard 6.6.47-current-rockchip #2 SMP Mon Aug 19 04:04:32 UTC 2024 armv7l GNU/Linux The kernel module in question is Open Source Mali Midgard GPU Kernel Driver, downloaded from ARM. I installed kernel headers through armbian-config: ls /usr/src/linux-headers-6.6.47-current-rockchip arch certs Documentation fs init ipc kernel Makefile Module.symvers rust scripts sound usr block crypto drivers include io_uring Kconfig lib mm net samples security tools virt When I run make with verbose option inside the module source directory, I get the following output: make V=1 make -C /lib/modules/6.6.47-current-rockchip/build M=/home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard EXTRA_CFLAGS="-I/home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/../../../../include -I/home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/../../../../tests/include " KBUILD_EXTRA_SYMBOLS="" modules make[1]: Entering directory '/usr/src/linux-headers-6.6.47-current-rockchip' make --no-print-directory -C /usr/src/linux-headers-6.6.47-current-rockchip \ -f /usr/src/linux-headers-6.6.47-current-rockchip/Makefile modules make -f ./scripts/Makefile.build obj=/home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard need-builtin=1 need-modorder=1 # cmd_modules_order /home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/modules.order { :; } > /home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/modules.order sh ./scripts/modules-check.sh /home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/modules.order make -f ./scripts/Makefile.modpost # MODPOST /home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/Module.symvers scripts/mod/modpost -M -o /home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/Module.symvers -T /home/loregen/libs-from-source/TX041-SW-99002-r26p0-01rel0/driver/product/kernel/drivers/gpu/arm/midgard/modules.order -i Module.symvers -e make -f ./scripts/Makefile.modfinal make[1]: Leaving directory '/usr/src/linux-headers-6.6.47-current-rockchip' I cannot figure out why the module doesn't build. 0 Quote
