Gibbz Posted November 19, 2024 Posted November 19, 2024 (edited) I'm trying to get my udev rule working on armbian. But I cant make anything work at all. I am wanting to rename the android usb tether to a standard name usb0. Ive tried the following rules /etc/udev/rules.d/99-usb-tether.rules SUBSYSTEM=="net", ACTION=="add", ATTRS{interface}=="RNDIS Ethernet Data", NAME="usb%k" SUBSYSTEM=="net", ACTION=="add", ATTRS{ID_USB_INTERFACES}=="*:e00103:*", NAME="usb%k" SUBSYSTEM=="net", ACTION=="add", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="4ee3", NAME="usb0" none of them work, also tried rebooting sudo udevadm control --reload-rules sudo udevadm trigger Ive ran the command: udevadm test /dev/bus/usb/002/002 Trying to open "/etc/systemd/hwdb/hwdb.bin"... Trying to open "/etc/udev/hwdb.bin"... Trying to open "/usr/lib/systemd/hwdb/hwdb.bin"... Trying to open "/usr/lib/udev/hwdb.bin"... === trie on-disk === tool version: 256 file size: 12592130 bytes header size 80 bytes strings 2650746 bytes nodes 9941304 bytes Loading kernel module index. Loaded 'libkmod.so.2' via dlopen() Failed to read $container of PID 1, ignoring: Permission denied Found cgroup2 on /sys/fs/cgroup/, full unified hierarchy Found container virtualization none. Using default interface naming scheme 'v255'. Parsed configuration file "/usr/lib/systemd/network/99-default.link" Parsed configuration file "/usr/lib/systemd/network/80-vm-vt.link" Parsed configuration file "/usr/lib/systemd/network/80-container-vz.link" Parsed configuration file "/usr/lib/systemd/network/80-container-ve.link" Parsed configuration file "/usr/lib/systemd/network/80-container-vb.link" Parsed configuration file "/usr/lib/systemd/network/80-6rd-tunnel.link" Parsed configuration file "/usr/lib/systemd/network/73-usb-net-by-mac.link" Created link configuration context. Reading rules file: /etc/udev/rules.d/10-wifi-disable-powermanagement.rules Reading rules file: /usr/lib/udev/rules.d/50-firmware.rules Reading rules file: /etc/udev/rules.d/50-mali.rules Reading rules file: /etc/udev/rules.d/50-rk3399-vpu.rules Reading rules file: /usr/lib/udev/rules.d/50-udev-default.rules Reading rules file: /etc/udev/rules.d/50-usb-realtek-net.rules Reading rules file: /usr/lib/udev/rules.d/55-dm.rules Reading rules file: /usr/lib/udev/rules.d/60-autosuspend.rules Reading rules file: /usr/lib/udev/rules.d/60-block.rules Reading rules file: /usr/lib/udev/rules.d/60-cdrom_id.rules Reading rules file: /usr/lib/udev/rules.d/60-dmi-id.rules Reading rules file: /usr/lib/udev/rules.d/60-drm.rules Reading rules file: /usr/lib/udev/rules.d/60-evdev.rules Reading rules file: /usr/lib/udev/rules.d/60-fido-id.rules Reading rules file: /usr/lib/udev/rules.d/60-infiniband.rules Reading rules file: /usr/lib/udev/rules.d/60-input-id.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-alsa.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-input.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-dm.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-mtd.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage-tape.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-storage.rules Reading rules file: /usr/lib/udev/rules.d/60-persistent-v4l.rules Reading rules file: /usr/lib/udev/rules.d/60-sensor.rules Reading rules file: /usr/lib/udev/rules.d/60-serial.rules Reading rules file: /usr/lib/udev/rules.d/64-btrfs.rules Reading rules file: /usr/lib/udev/rules.d/64-ext4.rules Reading rules file: /usr/lib/udev/rules.d/70-camera.rules Reading rules file: /usr/lib/udev/rules.d/70-joystick.rules Reading rules file: /usr/lib/udev/rules.d/70-memory.rules Reading rules file: /usr/lib/udev/rules.d/70-mouse.rules Reading rules file: /usr/lib/udev/rules.d/70-power-switch.rules Reading rules file: /usr/lib/udev/rules.d/70-touchpad.rules Reading rules file: /usr/lib/udev/rules.d/70-uaccess.rules Reading rules file: /usr/lib/udev/rules.d/71-axp-power-button.rules Reading rules file: /usr/lib/udev/rules.d/71-seat.rules Reading rules file: /usr/lib/udev/rules.d/73-seat-late.rules Reading rules file: /usr/lib/udev/rules.d/73-special-net-names.rules Reading rules file: /usr/lib/udev/rules.d/75-net-description.rules Reading rules file: /usr/lib/udev/rules.d/75-probe_mtd.rules Reading rules file: /usr/lib/udev/rules.d/78-sound-card.rules Reading rules file: /usr/lib/udev/rules.d/80-debian-compat.rules Reading rules file: /usr/lib/udev/rules.d/80-docker.rules Reading rules file: /usr/lib/udev/rules.d/80-drivers.rules Reading rules file: /usr/lib/udev/rules.d/80-net-setup-link.rules Reading rules file: /usr/lib/udev/rules.d/81-net-dhcp.rules Reading rules file: /usr/lib/udev/rules.d/90-alsa-restore.rules Reading rules file: /etc/udev/rules.d/90-chromium-video.rules Reading rules file: /usr/lib/udev/rules.d/90-console-setup.rules Reading rules file: /usr/lib/udev/rules.d/90-iocost.rules Failed to open /run/udev/rules.d/90-netplan.rules, ignoring: Permission denied Failed to read rules file /run/udev/rules.d/90-netplan.rules, ignoring: Permission denied Reading rules file: /usr/lib/udev/rules.d/95-dm-notify.rules Reading rules file: /usr/lib/udev/rules.d/96-e2scrub.rules Reading rules file: /usr/lib/udev/rules.d/97-hid2hci.rules Reading rules file: /usr/lib/udev/rules.d/99-systemd.rules Reading rules file: /etc/udev/rules.d/99-usb-tether.rules 2-1: /usr/lib/udev/rules.d/50-udev-default.rules:19 Importing properties from results of builtin command 'usb_id' 2-1: /usr/lib/udev/rules.d/50-udev-default.rules:19 Importing properties from results of builtin command 'hwdb --subsystem=usb' 2-1: hwdb modalias key: "usb:v18D1p4EE3:Pixel 5a" 2-1: /usr/lib/udev/rules.d/50-udev-default.rules:29 Importing properties from results of builtin command 'path_id' 2-1: /usr/lib/udev/rules.d/50-udev-default.rules:69 MODE 0664 Properties: DEVPATH=/devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.4.auto/usb2/2-1 DEVNAME=/dev/bus/usb/002/002 DEVTYPE=usb_device DRIVER=usb PRODUCT=18d1/4ee3/440 TYPE=0/0/0 BUSNUM=002 DEVNUM=002 MAJOR=189 MINOR=129 SUBSYSTEM=usb ACTION=add TAGS=:seat: ID_BUS=usb ID_MODEL=Pixel_5a ID_MODEL_ENC=Pixel\x205a ID_MODEL_ID=4ee3 ID_SERIAL=Google_Pixel_5a_18161JECB02915 ID_SERIAL_SHORT=18161JECB02915 ID_VENDOR=Google ID_VENDOR_ENC=Google ID_VENDOR_ID=18d1 ID_REVISION=0440 ID_USB_MODEL=Pixel_5a ID_USB_MODEL_ENC=Pixel\x205a ID_USB_MODEL_ID=4ee3 ID_USB_SERIAL=Google_Pixel_5a_18161JECB02915 ID_USB_SERIAL_SHORT=18161JECB02915 ID_USB_VENDOR=Google ID_USB_VENDOR_ENC=Google ID_USB_VENDOR_ID=18d1 ID_USB_REVISION=0440 ID_USB_INTERFACES=:e00103:0a0000: ID_VENDOR_FROM_DATABASE=Google Inc. ID_MODEL_FROM_DATABASE=Nexus/Pixel Device (tether) ID_PATH_WITH_USB_REVISION=platform-xhci-hcd.4.auto-usbv3-0:1 ID_PATH=platform-xhci-hcd.4.auto-usb-0:1 ID_PATH_TAG=platform-xhci-hcd_4_auto-usb-0_1 REALTEK_NIC_MODE=1 CURRENT_TAGS=:seat: ID_FOR_SEAT=usb-platform-xhci-hcd_4_auto-usb-0_1 USEC_INITIALIZED=3084785 Tags: seat Inotify watch: disabled Device node permission: 0664 Unload kernel module index. Unloaded link configuration context. it looks like another earlier rule is overwriting my rule possibly?? /usr/lib/udev/rules.d/50-udev-default.rules Ive also tried seting up .link files, which seems like a simpler solution if it works... But it doesnt. /etc/systemd/network/99-usb-tether.link [Match] OriginalName=enx* [Link] Name=usb0 How can i get my rule to take preference? Edited November 19, 2024 by Gibbz 0 Quote
Solution Gibbz Posted November 19, 2024 Author Solution Posted November 19, 2024 i got it working by renaming the files with smaller numbers. /etc/systemd/network/10-internet-usb.link /etc/systemd/network/10-internet-usb.network 0 Quote
