Im using armbian server edition. Im trying to setup my box to route internet from end0 (192.168.1.6) to internet on usb0 (dhcp). Im running dns & dhcp via docker adguard - but assume thats not working for now because once the nftable rules are applied I cannot access their web interfaces. But for now ping with ip is okay.
With my current setup I can ping the internet from the 'router' via the interface usb0. But I cannot ping from the interface end0.
ping 8.8.8.8 -I usb0 <- works
ping 8.8.8.8 -I end0 <- Destination Host Unreachable
Do I need to setup any static routes? Or should nftables handle all the routing?
Ive tried several guides with various nftable rules, but none of them work:
https://peppe8o.com/raspberry-pi-portable-hotspot-with-android-usb-tethering/
https://oxcrag.net/projects/linux-router-part-1-routing-nat-and-nftables/
https://wiki.nftables.org/wiki-nftables/index.php/Simple_ruleset_for_a_home_router
my network config:
usb0:
[Match]
Name=usb0
[Network]
DHCP=yes
end0:
[Match]
Name=end0
[Network]
Address=192.168.1.6/24
my nftables:
table inet filter {
        chain input {
                type filter hook input priority filter; policy accept;
        chain forward {
                type filter hook forward priority filter; policy accept;
                iif "end0" oif "usb0" accept
                iif "usb0" oif "end0" accept
        chain output {
                type filter hook output priority filter; policy accept;
table ip nat {
        chain prerouting {
                type nat hook prerouting priority filter; policy accept;
        chain postrouting {
                type nat hook postrouting priority srcnat; policy accept;
                oif "usb0" masquerade
my routes:
default via 192.168.102.208 dev usb0
default via 192.168.102.208 dev usb0 proto dhcp src 192.168.102.114 metric 1024
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown <- docker?
172.18.0.0/16 dev br-cc00a7d88795 proto kernel scope link src 172.18.0.1 <- docker?
192.168.1.0/24 dev end0 proto kernel scope link src 192.168.1.6
192.168.102.0/24 dev usb0 proto kernel scope link src 192.168.102.114 metric 1024
192.168.102.208 dev usb0 proto dhcp scope link src 192.168.102.114 metric 1024
Edited by Gibbz
