I always have a boot problem with the OP lite after operating approximately for 2 weeks !!
When the problem occurs, I got the following message while the system is booting :
U-Boot SPL 2017.01-armbian (Feb 02 2017 - 02:58:38)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2017.01-armbian (Feb 02 2017 - 02:58:38 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Lite
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
6944 bytes read in 136 ms (49.8 KiB/s)
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2652 bytes read in 169 ms (14.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
8646 bytes read in 127 ms (66.4 KiB/s)
5163574 bytes read in 487 ms (10.1 MiB/s)
4754648 bytes read in 475 ms (9.5 MiB/s)
** File not found /boot/.next **
** File not found .next **
34704 bytes read in 442 ms (76.2 KiB/s)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    5163510 Bytes = 4.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Starting kernel ...
Error: unrecognized/unsupported machine ID (r1 = 0x00000000).
Available machine support:
ID (hex)        NAME
00001029        sun8i
Please check your kernel config and/or bootloader.
Even though, if I just connect the memory card to my computer and reconnect it to the OP lite again, everything seem to work fine!
root@orangepilite:~# armbianmonitor -u
/var/log/armhwinfo.log has been uploaded to http://sprunge.us/aZgb
Please any help would be appreciated.
