Hello,
I have an issue with my box, which keeps freezing without any apparent error signals.
It's probably me not knowing where to look, so I'm kindly asking for your help to understand how to proceed in identifying the root cause.
My box is a MXQ PRO 4K (Leelbox), I'm using meson-gxbb-p201.dtb and u-boot-s905.
Current version: v25.2 rolling for aml-s9xx-box running Armbian Linux 6.6.66-current-meson64
The box works perfectly for some hours, then it goes offline and disappears. The led is still blue (on), but even if I attach and hdmi cable there's no signal.
I tried to leave a couple of ssh sessions opened to see what's happening before the crash, this is what I see:
htop
    0[||||||||        5.4%] Tasks: 35, 10 thr, 104 kthr; 1 running
    1[|||        2.0%] Load average: 0.11 0.08 0.03
    2[||        1.3%] Uptime: 00:33:16
    3[||||        2.6%]
  Mem[|||||||||||||||||||||||||||||||||||||||||||||||||        143M/925M]
  Swp[        0K/463M]
  [Main] [I/O]
    PID USER       PRI  NI  VIRT   RES   SHR S  CPU%▽MEM%   TIME+  Command
   2320 alberto     20   0 11268  7296  3200 R   2.7  0.8  0:50.34 htop
   1578 root        20   0  329M 21564 14720 S   1.3  2.3  0:01.83 /usr/sbin/NetworkManager --no-daemon
   1336 systemd-re  20   0 21492 12288 10240 S   0.7  1.3  0:00.55 /usr/lib/systemd/systemd-resolved
   1591 root        20   0 17500 10240  8960 S   0.7  1.1  0:05.76 /usr/sbin/wpa_supplicant -u -s -O DIR=/run/wpa_supplicant GROUP=netdev
   2628 alberto     20   0  6944  3584  2176 S   0.7  0.4  0:15.46 watch -n 1 cat /etc/armbianmonitor/datasources/soctemp
      1 root        20   0 21852 11724  8524 S   0.0  1.2  0:04.98 /sbin/init splash
   1105 root        20   0 26412  6220  4556 S   0.0  0.7  0:00.41 /usr/lib/systemd/systemd-udevd
   1295 root        19  -1 28008  7808  6912 S   0.0  0.8  0:00.41 /usr/lib/systemd/systemd-journald
   1334 _rpc        20   0  8320  3456  3072 S   0.0  0.4  0:00.03 /sbin/rpcbind -f -w
   1386 root        20   0  6720  2048  1920 S   0.0  0.2  0:00.04 /usr/sbin/cron -f -P
   1395 messagebus  20   0  8648  3712  3200 S   0.0  0.4  0:00.75 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
   1404 root        20   0 17468  7424  6656 S   0.0  0.8  0:00.30 /usr/lib/systemd/systemd-logind
   1446 syslog      20   0  217M  6016  3200 S   0.0  0.6  0:00.12 /usr/sbin/rsyslogd -n -iNONE
   1560 syslog      20   0  217M  6016  3200 S   0.0  0.6  0:00.02 /usr/sbin/rsyslogd -n -iNONE
   1561 syslog      20   0  217M  6016  3200 S   0.0  0.6  0:00.00 /usr/sbin/rsyslogd -n -iNONE
   1562 syslog      20   0  217M  6016  3200 S   0.0  0.6  0:00.03 /usr/sbin/rsyslogd -n -iNONE
   1571 root        20   0 27048  1152  1152 S   0.0  0.1  0:00.00 /usr/sbin/rngd -r /dev/hwrng
   1573 root        20   0 27048  1152  1152 S   0.0  0.1  0:00.00 /usr/sbin/rngd -r /dev/hwrng
   1574 root        20   0 27048  1152  1152 S   0.0  0.1  0:00.00 /usr/sbin/rngd -r /dev/hwrng
   1575 root        20   0 27048  1152  1152 S   0.0  0.1  0:00.00 /usr/sbin/rngd -r /dev/hwrng
   1687 root        20   0  329M 21564 14720 S   0.0  2.3  0:00.09 /usr/sbin/NetworkManager --no-daemon
   1691 root        20   0  329M 21564 14720 S   0.0  2.3  0:00.00 /usr/sbin/NetworkManager --no-daemon
   1694 root        20   0  329M 21564 14720 S   0.0  2.3  0:00.37 /usr/sbin/NetworkManager --no-daemon
   1922 root        20   0  108M 21376 12416 S   0.0  2.3  0:00.48 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
   1923 vnstat      20   0  5180  3328  2688 S   0.0  0.4  0:00.57 /usr/sbin/vnstatd -n
   1944 _chrony     20   0 19696  3112  2432 S   0.0  0.3  0:00.16 /usr/sbin/chronyd -F 1
   1945 _chrony     20   0 11568  3384  2816 S   0.0  0.4  0:00.01 /usr/sbin/chronyd -F 1
   1953 root        20   0  5292  1408  1408 S   0.0  0.1  0:00.02 /sbin/agetty -o -p -- \u --keep-baud 115200,57600,38400,9600 - linux
   1957 root        20   0  5676  1536  1536 S   0.0  0.2  0:00.03 /sbin/agetty -o -p -- \u --noclear - linux
   1961 root        20   0  108M 21376 12416 S   0.0  2.3  0:00.00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
   2001 root        20   0 12052  7168  6144 S   0.0  0.8  0:00.06 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
   2008 root        20   0 15452  6600  5248 S   0.0  0.7  0:00.28 sshd: alberto [priv]
   2028 alberto     20   0 20040 10624  8704 S   0.0  1.1  0:00.35 /usr/lib/systemd/systemd --user
   2029 alberto     20   0 21240  2952  1664 S   0.0  0.3  0:00.00 (sd-pam)
   2308 alberto     20   0 15712  5996  4352 S   0.0  0.6  0:01.73 sshd: alberto@pts/0
   2309 alberto     20   0  8360  4992  3456 S   0.0  0.5  0:00.11 -bash
   2327 root        20   0 15456  6500  5248 S   0.0  0.7  0:00.29 sshd: alberto [priv]
   2598 alberto     20   0 15716  6004  4352 S   0.0  0.6  0:00.83 sshd: alberto
   2599 alberto     20   0  8360  4864  3328 S   0.0  0.5  0:00.11 -bash
   2716 root        20   0 15456  6464  5120 S   0.0  0.7  0:00.21 sshd: alberto [priv]
   3000 alberto     20   0 15716  5876  4352 S   0.0  0.6  0:00.06 sshd: alberto@pts/2
   3001 alberto     20   0  8360  4992  3456 S   0.0  0.5  0:00.11 -bash
   3027 root        20   0 16344  5760  4864 S   0.0  0.6  0:00.39 sudo tail -f /var/log/syslog
   3037 root        20   0 16344  2272  1408 S   0.0  0.2  0:00.00 sudo tail -f /var/log/syslog
   3038 root        20   0  5288  1792  1792 S   0.0  0.2  0:00.02 tail -f /var/log/syslog
syslog
2024-12-17T23:31:37.173830+01:00 box systemd[2028]: Queued start job for default target default.target.
2024-12-17T23:31:37.219955+01:00 box systemd[2028]: Created slice app.slice - User Application Slice.
2024-12-17T23:31:37.220285+01:00 box systemd[2028]: Started launchpadlib-cache-clean.timer - Clean up old files in the Launchpadlib cache.
2024-12-17T23:31:37.220492+01:00 box systemd[2028]: Reached target paths.target - Paths.
2024-12-17T23:31:37.220662+01:00 box systemd[2028]: Reached target timers.target - Timers.
2024-12-17T23:31:37.223802+01:00 box systemd[2028]: Starting dbus.socket - D-Bus User Message Bus Socket...
2024-12-17T23:31:37.224702+01:00 box systemd[2028]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
2024-12-17T23:31:37.225477+01:00 box systemd[2028]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
2024-12-17T23:31:37.226202+01:00 box systemd[2028]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
2024-12-17T23:31:37.229850+01:00 box systemd[2028]: Starting gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation)...
2024-12-17T23:31:37.230650+01:00 box systemd[2028]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
2024-12-17T23:31:37.232491+01:00 box systemd[2028]: Listening on keyboxd.socket - GnuPG public key management service.
2024-12-17T23:31:37.233374+01:00 box systemd[2028]: Listening on pk-debconf-helper.socket - debconf communication socket.
2024-12-17T23:31:37.275203+01:00 box systemd[2028]: Listening on dbus.socket - D-Bus User Message Bus Socket.
2024-12-17T23:31:37.315749+01:00 box systemd[2028]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
2024-12-17T23:31:37.316387+01:00 box systemd[2028]: Reached target sockets.target - Sockets.
2024-12-17T23:31:37.316707+01:00 box systemd[2028]: Reached target basic.target - Basic System.
2024-12-17T23:31:37.316932+01:00 box systemd[2028]: Reached target default.target - Main User Target.
2024-12-17T23:31:37.317124+01:00 box systemd[2028]: Startup finished in 493ms.
2024-12-17T23:31:37.317283+01:00 box systemd[1]: Started user@1000.service - User Manager for UID 1000.
2024-12-17T23:31:37.322177+01:00 box systemd[1]: Started session-3.scope - Session 3 of User alberto.
2024-12-17T23:32:08.385083+01:00 box chronyd[1944]: Selected source 185.157.229.254 (0.ubuntu.pool.ntp.org)
2024-12-17T23:32:08.385349+01:00 box chronyd[1944]: System clock wrong by 29.550363 seconds
2024-12-17T23:32:08.386136+01:00 box systemd-resolved[1336]: Clock change detected. Flushing caches.
2024-12-17T23:32:08.386328+01:00 box chronyd[1944]: System clock was stepped by 29.550363 seconds
2024-12-17T23:32:08.386523+01:00 box chronyd[1944]: System clock TAI offset set to 37 seconds
2024-12-17T23:32:12.678816+01:00 box systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
2024-12-17T23:32:21.333843+01:00 box systemd[1]: systemd-fsckd.service: Deactivated successfully.
2024-12-17T23:32:25.920144+01:00 box systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2024-12-17T23:33:46.439874+01:00 box systemd[1]: Started session-5.scope - Session 5 of User alberto.
2024-12-17T23:35:22.941721+01:00 box chronyd[1944]: Selected source 185.125.190.58 (ntp.ubuntu.com)
2024-12-17T23:37:24.869799+01:00 box systemd[2028]: launchpadlib-cache-clean.service - Clean up old files in the Launchpadlib cache was skipped because of an unmet condition check (ConditionPathExists=/home/alberto/.launchpadlib/api.launchpad.net/cache).
2024-12-17T23:37:32.399838+01:00 box systemd[1]: Started session-6.scope - Session 6 of User alberto.
2024-12-17T23:45:01.153740+01:00 box CRON[4452]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
2024-12-17T23:47:02.263368+01:00 box systemd[1]: Starting systemd-tmpfiles-clean.service - Cleanup of Temporary Directories...
2024-12-17T23:47:02.495896+01:00 box systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
2024-12-17T23:47:02.496769+01:00 box systemd[1]: Finished systemd-tmpfiles-clean.service - Cleanup of Temporary Directories.
2024-12-18T00:00:01.245939+01:00 box CRON[7112]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
2024-12-18T00:00:01.248612+01:00 box CRON[7111]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
2024-12-18T00:00:06.864641+01:00 box systemd[1]: Starting dpkg-db-backup.service - Daily dpkg database backup service...
2024-12-18T00:00:06.874674+01:00 box systemd[1]: Starting fake-hwclock-save.service - Save the current clock...
2024-12-18T00:00:06.896392+01:00 box systemd[1]: Starting logrotate.service - Rotate log files...
2024-12-18T00:00:06.910237+01:00 box systemd[1]: fake-hwclock-save.service: Deactivated successfully.
2024-12-18T00:00:06.911409+01:00 box systemd[1]: Finished fake-hwclock-save.service - Save the current clock.
2024-12-18T00:00:06.980551+01:00 box armbian-ramlog[7195]: Wed Dec 18 00:00:06 CET 2024: Syncing logs to storage
2024-12-18T00:00:06.998171+01:00 box armbian-ramlog[7200]: sending incremental file list
2024-12-18T00:00:07.002592+01:00 box armbian-ramlog[7200]: ./
2024-12-18T00:00:07.004123+01:00 box armbian-ramlog[7200]: armbian-hardware-monitor.log
2024-12-18T00:00:07.005826+01:00 box armbian-ramlog[7200]: auth.log
2024-12-18T00:00:07.008697+01:00 box armbian-ramlog[7200]: boot.log
2024-12-18T00:00:07.009601+01:00 box armbian-ramlog[7200]: dmesg
2024-12-18T00:00:07.010769+01:00 box armbian-ramlog[7200]: dmesg.0
2024-12-18T00:00:07.012518+01:00 box armbian-ramlog[7200]: kern.log
2024-12-18T00:00:07.142535+01:00 box armbian-ramlog[7200]: lastlog
2024-12-18T00:00:08.218759+01:00 box systemd[1]: logrotate.service: Deactivated successfully.
2024-12-18T00:00:08.219632+01:00 box systemd[1]: Finished logrotate.service - Rotate log files.
client_loop: send disconnect: Connection reset
neofetch:
      █ █ █ █ █ █ █ █ █ █ █      OS: Armbian (25.2.0-trunk.186) aarch64
     ███████████████████████     Host: Amlogic Meson GXBB P201 Development Board
   ▄▄██                   ██▄▄   Kernel: 6.6.66-current-meson64
   ▄▄██    ███████████    ██▄▄   Uptime: 18 mins
   ▄▄██   ██         ██   ██▄▄   Packages: 526 (dpkg)
   ▄▄██   ██         ██   ██▄▄   Shell: bash 5.2.21
   ▄▄██   ██         ██   ██▄▄   Resolution: 720x576i
   ▄▄██   █████████████   ██▄▄   Terminal: /dev/pts/0
   ▄▄██   ██         ██   ██▄▄   CPU: ARMv8 rev 4 (v8l) (4) @ 1.536GHz
   ▄▄██   ██         ██   ██▄▄   Memory: 146MiB / 925MiB
Any ideas?
Kind Regards,
Alberto
Hi, I tried with Debian, stable, but the problem is still there.
This time when the ssh connection dropped I received this error:
kernel:[132648.806302] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
This is what comes up after restarting with
armbianmonitor -u
https://paste.next.armbian.com/dalewonika
I'm not sure... but check these things to get more information and do more troubleshooting: Check your power supply for frayed wires and try a different power supply that puts out the same volts but more amperes. If you booted from a SD card or a USB flash drive, check it for data corruption and physical damage. Also try another card or USB drive. Check the motherboard and CPU for excessive heat above 60 Celsius. If it's too hot, it can do strange things. Create a cron job as a regular user to get kernel messages and write them to a text file (every 1 minute). Run "crontab -e"  and add the text I wrote below to the crontab and save the file. Later open and read the kernel-dmesg.txt file. I hope that helps some.
*/1 * * * * /usr/bin/dmesg > $HOME/kernel-dmesg.txt
Hi Pita Bread, thanks for the support.
  Quote
Expand
I tried with SD and USB, same error. That's why I tried to reinstall everything using Debian instead of Ubuntu (on the USB at the moment), but the problem is still there. At least now there's an Oops: 0000000096000004 which is better than nothing :D
  Quote
Expand
This was the first thing I checked, temperature was 41°C or similar when it crashed.
  Quote
Expand
I set it, let's see. The board was running for a couple of days before it crashed, Let's hope it crashes sooner this time :(
About the wires.. I hope they are not frayed, I will try to see if I can find another power supplier.
Thanks again,
Alb
Hello,
it crashed and this is the content of kernel-dmesg.txt.
I see an interesting "Received SIGTERM from PID 1", does it mean the board was shutting down? Can this be related to some kind of automatic update not going the right way?
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.6.63-current-meson64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Fri Nov 22 14:38:37 UTC 2024
[    0.000000] Machine model: Amlogic Meson GXBB P201 Development Board
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000002b000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000002b000000..0x000000003affffff (262144 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000000000000..0x0000000000ffffff (16384 KiB) nomap non-reusable hwrom@0
[    0.000000] OF: reserved mem: 0x0000000005000000..0x00000000052fffff (3072 KiB) nomap non-reusable secmon@5000000
[    0.000000] OF: reserved mem: 0x0000000005300000..0x00000000072fffff (32768 KiB) nomap non-reusable secmon@5300000
[    0.000000] OF: reserved mem: 0x0000000010000000..0x00000000101fffff (2048 KiB) nomap non-reusable secmon@10000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000003fe5afff]
[    0.000000] NUMA: NODE_DATA [mem 0x3fc3d940-0x3fc3ffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fe5afff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000000ffffff]
[    0.000000]   node   0: [mem 0x0000000001000000-0x0000000004ffffff]
[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000072fffff]
[    0.000000]   node   0: [mem 0x0000000007300000-0x000000000fffffff]
[    0.000000]   node   0: [mem 0x0000000010000000-0x00000000101fffff]
[    0.000000]   node   0: [mem 0x0000000010200000-0x000000003fe5afff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fe5afff]
[    0.000000] On node 0, zone DMA: 421 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 22 pages/cpu s51432 r8192 d30488 u90112
[    0.000000] pcpu-alloc: s51432 r8192 d30488 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 843419
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=UUID=31bccdf3-c308-422e-b8af-f698deb5e256 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 257633
[    0.000000] Policy zone: DMA
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 1MB
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x000000003e928000-0x000000003ea28000] (1MB)
[    0.000000] Memory: 666568K/1046892K available (16192K kernel code, 1698K rwdata, 4964K rodata, 3776K init, 606K bss, 118180K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000214] Console: colour dummy device 80x25
[    0.000222] printk: console [tty0] enabled
[    0.000677] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000697] pid_max: default: 32768 minimum: 301
[    0.000770] LSM: initializing lsm=capability,yama,apparmor,integrity
[    0.000800] Yama: becoming mindful.
[    0.000883] AppArmor: AppArmor initialized
[    0.000968] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.000989] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.002645] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.002729] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.002927] rcu: Hierarchical SRCU implementation.
[    0.002938] rcu:     Max phase no-delay instances is 1000.
[    0.004361] EFI services will not be available.
[    0.004645] smp: Bringing up secondary CPUs ...
[    0.005694] Detected VIPT I-cache on CPU1
[    0.005788] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.006884] Detected VIPT I-cache on CPU2
[    0.006938] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.007954] Detected VIPT I-cache on CPU3
[    0.007997] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.008091] smp: Brought up 1 node, 4 CPUs
[    0.008143] SMP: Total of 4 processors activated.
[    0.008152] CPU features: detected: 32-bit EL0 Support
[    0.008160] CPU features: detected: 32-bit EL1 Support
[    0.008169] CPU features: detected: CRC32 instructions
[    0.008235] CPU: All CPU(s) started at EL2
[    0.008252] alternatives: applying system-wide alternatives
[    0.009811] devtmpfs: initialized
[    0.014888] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.014954] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.021392] pinctrl core: initialized pinctrl subsystem
[    0.021825] DMI not present or invalid.
[    0.022385] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.023852] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.023964] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.024145] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.024203] audit: initializing netlink subsys (disabled)
[    0.024373] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[    0.024768] thermal_sys: Registered thermal governor 'fair_share'
[    0.024773] thermal_sys: Registered thermal governor 'bang_bang'
[    0.024783] thermal_sys: Registered thermal governor 'step_wise'
[    0.024792] thermal_sys: Registered thermal governor 'user_space'
[    0.024831] cpuidle: using governor menu
[    0.025101] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.025195] ASID allocator initialised with 65536 entries
[    0.025823] Serial: AMBA PL011 UART driver
[    0.032983] platform d0100000.vpu: Fixed dependency cycle(s) with /soc/hdmi-tx@c883a000
[    0.033157] platform d0100000.vpu: Fixed dependency cycle(s) with /soc/hdmi-tx@c883a000
[    0.033215] platform c883a000.hdmi-tx: Fixed dependency cycle(s) with /soc/vpu@d0100000
[    0.034991] platform d0100000.vpu: Fixed dependency cycle(s) with /cvbs-connector
[    0.035052] platform cvbs-connector: Fixed dependency cycle(s) with /soc/vpu@d0100000
[    0.035183] platform c883a000.hdmi-tx: Fixed dependency cycle(s) with /hdmi-connector
[    0.035240] platform hdmi-connector: Fixed dependency cycle(s) with /soc/hdmi-tx@c883a000
[    0.035783] Modules: 25904 pages in range for non-PLT usage
[    0.035788] Modules: 517424 pages in range for PLT usage
[    0.036483] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.036506] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.036516] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.036526] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.036536] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.036545] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.036556] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.036565] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.037205] cryptd: max_cpu_qlen set to 1000
[    0.104229] raid6: neonx8   gen()  2751 MB/s
[    0.172278] raid6: neonx4   gen()  2814 MB/s
[    0.240327] raid6: neonx2   gen()  2671 MB/s
[    0.308372] raid6: neonx1   gen()  2292 MB/s
[    0.376418] raid6: int64x8  gen()  1749 MB/s
[    0.444462] raid6: int64x4  gen()  2051 MB/s
[    0.512504] raid6: int64x2  gen()  1788 MB/s
[    0.580566] raid6: int64x1  gen()  1324 MB/s
[    0.580576] raid6: using algorithm neonx4 gen() 2814 MB/s
[    0.648600] raid6: .... xor() 1996 MB/s, rmw enabled
[    0.648610] raid6: using neon recovery algorithm
[    0.649018] ACPI: Interpreter disabled.
[    0.649530] iommu: Default domain type: Translated
[    0.649552] iommu: DMA domain TLB invalidation policy: strict mode
[    0.650185] SCSI subsystem initialized
[    0.650414] usbcore: registered new interface driver usbfs
[    0.650451] usbcore: registered new interface driver hub
[    0.650490] usbcore: registered new device driver usb
[    0.650748] pps_core: LinuxPPS API ver. 1 registered
[    0.650758] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.650781] PTP clock support registered
[    0.650903] EDAC MC: Ver: 3.0.0
[    0.651257] scmi_core: SCMI protocol bus registered
[    0.652176] NetLabel: Initializing
[    0.652187] NetLabel:  domain hash size = 128
[    0.652195] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.652251] NetLabel:  unlabeled traffic allowed by default
[    0.652260] mctp: management component transport protocol core
[    0.652269] NET: Registered PF_MCTP protocol family
[    0.652446] vgaarb: loaded
[    0.652881] clocksource: Switched to clocksource arch_sys_counter
[    0.653169] VFS: Disk quotas dquot_6.6.0
[    0.653211] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.653686] AppArmor: AppArmor Filesystem Enabled
[    0.653772] pnp: PnP ACPI: disabled
[    0.659616] NET: Registered PF_INET protocol family
[    0.659802] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.660728] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.660905] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.660947] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.661080] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.661271] TCP: Hash tables configured (established 8192 bind 8192)
[    0.661485] MPTCP token hash table entries: 1024 (order: 2, 24576 bytes, linear)
[    0.661544] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.661578] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.661725] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.661770] PCI: CLS 0 bytes, default 64
[    0.662024] Trying to unpack rootfs image as initramfs...
[    0.665063] kvm [1]: IPA Size Limit: 40 bits
[    0.666023] kvm [1]: vgic interrupt IRQ9
[    0.666072] kvm [1]: Hyp mode initialized successfully
[    0.667705] Initialise system trusted keyrings
[    0.667789] Key type blacklist registered
[    0.667945] workingset: timestamp_bits=44 max_order=18 bucket_order=0
[    0.667999] zbud: loaded
[    0.668435] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.668796] fuse: init (API version 7.39)
[    0.670468] integrity: Platform Keyring initialized
[    0.695534] xor: measuring software checksum speed
[    0.696592]    8regs           :  3217 MB/sec
[    0.697656]    32regs          :  3124 MB/sec
[    0.698774]    arm64_neon      :  2990 MB/sec
[    0.698784] xor: using function: 8regs (3217 MB/sec)
[    0.698805] Key type asymmetric registered
[    0.698815] Asymmetric key parser 'x509' registered
[    0.698961] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.699181] io scheduler mq-deadline registered
[    0.699196] io scheduler kyber registered
[    0.699252] io scheduler bfq registered
[    0.699635] irq_meson_gpio: 133 to 8 gpio interrupt mux initialized
[    0.706500] EINJ: ACPI disabled.
[    0.712701] soc soc0: Amlogic Meson GXBB (S905) Revision 1f:c (13:1) Detected
[    0.714045] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.717919] Serial: AMBA driver
[    0.718562] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 14, base_baud = 1500000) is a meson_uart
[    0.718628] printk: console [ttyAML0] enabled
[    1.251401] Freeing initrd memory: 14924K
[    1.927265] loop: module loaded
[    1.929631] tun: Universal TUN/TAP device driver, 1.6
[    1.932271] thunder_xcv, ver 1.0
[    1.933525] thunder_bgx, ver 1.0
[    1.936222] nicpf, ver 1.0
[    1.939352] e1000e: Intel(R) PRO/1000 Network Driver
[    1.943927] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.949770] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.955013] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.960958] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.966737] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.972843] sky2: driver version 1.30
[    1.976975] VFIO - User Level meta-driver version: 0.3
[    1.982849] usbcore: registered new interface driver usb-storage
[    1.988610] mousedev: PS/2 mouse device common for all mice
[    1.993510] i2c_dev: i2c /dev entries driver
[    1.999350] sdhci: Secure Digital Host Controller Interface driver
[    2.003143] sdhci: Copyright(c) Pierre Ossman
[    2.007710] Synopsys Designware Multimedia Card Interface Driver
[    2.014064] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.015014] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[    2.024614] ledtrig-cpu: registered to indicate activity on CPUs
[    2.031169] meson-sm: secure-monitor enabled
[    2.035299] hid: raw HID events driver (C) Jiri Kosina
[    2.039908] usbcore: registered new interface driver usbhid
[    2.045313] usbhid: USB HID core driver
[    2.049521] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[    2.057119] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    2.065535] NET: Registered PF_INET6 protocol family
[    2.069910] Segment Routing with IPv6
[    2.072591] In-situ OAM (IOAM) with IPv6
[    2.073365] mmc1: Failed to initialize a non-removable card
[    2.076522] NET: Registered PF_PACKET protocol family
[    2.087091] 8021q: 802.1Q VLAN Support v1.8
[    2.091152] Key type dns_resolver registered
[    2.110309] registered taskstats version 1
[    2.110519] Loading compiled-in X.509 certificates
[    2.116672] zswap: loaded using pool zstd/zbud
[    2.126122] Key type .fscrypt registered
[    2.126174] Key type fscrypt-provisioning registered
[    2.133087] Btrfs loaded, zoned=yes, fsverity=yes
[    2.134242] Key type encrypted registered
[    2.138256] AppArmor: AppArmor sha1 policy hashing enabled
[    2.157496] meson-drm d0100000.vpu: Queued 2 outputs on vpu
[    2.184999] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    2.189704] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    2.197240] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops 0xffff80008110a758)
[    2.205191] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
[    2.249548] Console: switching to colour frame buffer device 90x36
[    2.270168] meson-drm d0100000.vpu: [drm] fb0: mesondrmfb frame buffer device
[    2.278189] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[    2.284596] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[    2.349104] dwc2 c9100000.usb: DWC OTG Controller
[    2.349210] dwc2 c9100000.usb: new USB bus registered, assigned bus number 1
[    2.355257] dwc2 c9100000.usb: irq 25, io mem 0xc9100000
[    2.360717] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.368691] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.375844] usb usb1: Product: DWC OTG Controller
[    2.380499] usb usb1: Manufacturer: Linux 6.6.63-current-meson64 dwc2_hsotg
[    2.387402] usb usb1: SerialNumber: c9100000.usb
[    2.392456] hub 1-0:1.0: USB hub found
[    2.395713] hub 1-0:1.0: 1 port detected
[    2.402043] meson-gx-mmc d0072000.mmc: Got CD GPIO
[    2.402068] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
[    2.402716] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[    2.412069] dwc2 c9000000.usb: supply vusb_d not found, using dummy regulator
[    2.423469] dwc2 c9000000.usb: supply vusb_a not found, using dummy regulator
[    2.440941] gpio irq setup: hwirq: 0x3A irqfirst: 0x34 irqlast: 0x3A pin[44]
[    2.443462] dwc2 c9000000.usb: DWC OTG Controller
[    2.446080] genirq: Setting trigger mode 3 for irq 29 failed (meson_gpio_irq_set_type+0x0/0x60)
[    2.450653] dwc2 c9000000.usb: new USB bus registered, assigned bus number 2
[    2.470378] mmc2: new high speed SDIO card at address 0001
[    2.471474] dwc2 c9000000.usb: irq 28, io mem 0xc9000000
[    2.489290] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.497339] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.504477] usb usb2: Product: DWC OTG Controller
[    2.509131] usb usb2: Manufacturer: Linux 6.6.63-current-meson64 dwc2_hsotg
[    2.516032] usb usb2: SerialNumber: c9000000.usb
[    2.521101] hub 2-0:1.0: USB hub found
[    2.524337] hub 2-0:1.0: 1 port detected
[    2.529406] clk: Disabling unused clocks
[    2.533830] Freeing unused kernel memory: 3776K
[    2.536617] Run /init as init process
[    2.540252]   with arguments:
[    2.540268]     /init
[    2.540280]     splash
[    2.540292]   with environment:
[    2.540302]     HOME=/
[    2.540313]     TERM=linux
[    2.704942] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.824940] usb 2-1: new high-speed USB device number 2 using dwc2
[    2.910385] meson-vrtc c81000a8.rtc: registered as rtc0
[    2.912005] meson-vrtc c81000a8.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
[    2.918339] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    2.927713] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.934818] usb 1-1: Product: USB2.0 Hub
[    2.940060] hub 1-1:1.0: USB hub found
[    2.942668] hub 1-1:1.0: 4 ports detected
[    2.945148] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[    2.953312] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[    2.959271] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[    2.965864] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    2.972101] meson8b-dwmac c9410000.ethernet:         DWMAC1000
[    2.977199] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[    2.984643] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[    2.992034] meson8b-dwmac c9410000.ethernet: COE Type 2
[    2.997196] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[    3.004200] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[    3.004454] usbcore: registered new device driver onboard-usb-hub
[    3.005711] meson8b-dwmac c9410000.ethernet: Normal descriptors
[    3.022459] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[    3.028237] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.036199] meson8b-dwmac c9410000.ethernet: device MAC address 9a:a2:5c:e4:19:27
[    3.037349] usb 2-1: New USB device found, idVendor=0781, idProduct=5571, bcdDevice= 1.26
[    3.051746] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.058771] usb 2-1: Product: Firebird USB Flash Drive
[    3.063862] usb 2-1: Manufacturer: SanDisk
[    3.067911] usb 2-1: SerialNumber: 4C532000070205121491
[    3.073622] usb-storage 2-1:1.0: USB Mass Storage device detected
[    3.079561] scsi host0: usb-storage 2-1:1.0
[    3.090796] usbcore: registered new interface driver uas
[    3.285103] onboard-usb-hub 1-1: reset high-speed USB device number 2 using dwc2
[    3.503799] hub 1-1:1.0: USB hub found
[    3.513211] hub 1-1:1.0: 4 ports detected
[    3.518412] hub 1-1:1.0: USB hub found
[    3.520166] hub 1-1:1.0: 4 ports detected
[    4.094366] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Fit       1.26 PQ: 0 ANSI: 5
[    4.112188] sd 0:0:0:0: [sda] 31266816 512-byte logical blocks: (16.0 GB/14.9 GiB)
[    4.119486] sd 0:0:0:0: [sda] Write Protect is off
[    4.122548] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    4.122746] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    4.135366]  sda: sda1 sda2
[    4.137294] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    4.151295] ICPlus IP101G stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    4.925678] EXT4-fs (sda2): mounted filesystem 31bccdf3-c308-422e-b8af-f698deb5e256 r/w with writeback data mode. Quota mode: none.
[    5.060988] random: crng init done
[    5.906484] systemd[1]: System time before build time, advancing clock.
[    5.930156] systemd[1]: Inserted module 'autofs4'
[    6.007051] systemd[1]: systemd 252.31-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    6.047239] systemd[1]: Detected architecture arm64.
[    6.069407] systemd[1]: Hostname set to <box>.
[    7.037228] systemd[1]: Queued start job for default target graphical.target.
[    7.076785] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    7.085434] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    7.092960] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    7.103212] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    7.113225] systemd[1]: Created slice user.slice - User and Session Slice.
[    7.119337] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    7.131028] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    7.142622] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    7.155887] systemd[1]: Expecting device dev-disk-by\x2duuid-D158\x2d6F4B.device - /dev/disk/by-uuid/D158-6F4B...
[    7.166970] systemd[1]: Expecting device dev-ttyAML0.device - /dev/ttyAML0...
[    7.173982] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[    7.181618] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    7.191461] systemd[1]: Reached target paths.target - Path Units.
[    7.197422] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[    7.204564] systemd[1]: Reached target slices.target - Slice Units.
[    7.210818] systemd[1]: Reached target swap.target - Swaps.
[    7.216277] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    7.226250] systemd[1]: Listening on syslog.socket - Syslog Socket.
[    7.232397] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    7.242472] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    7.253241] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    7.263139] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    7.273692] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    7.280928] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[    7.291218] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    7.300864] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    7.343470] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[    7.362301] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    7.373340] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    7.380863] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    7.400187] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    7.416493] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    7.430975] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    7.446173] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    7.460788] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    7.472741] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    7.484138] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    7.499750] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    7.509181] device-mapper: uevent: version 1.0.3
[    7.512298] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    7.512779] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    7.532769] systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl).
[    7.550988] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    7.589706] systemd[1]: Starting systemd-journald.service - Journal Service...
[    7.606331] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    7.618904] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
[    7.637884] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    7.653925] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    7.671118] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[    7.678473] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    7.686276] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    7.698623] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[    7.710179] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    7.722115] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.727586] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    7.734931] EXT4-fs (sda2): re-mounted 31bccdf3-c308-422e-b8af-f698deb5e256 r/w. Quota mode: none.
[    7.748073] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    7.753943] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[    7.768526] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.772867] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[    7.783537] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.788988] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    7.800568] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.804960] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    7.815157] systemd[1]: Started systemd-journald.service - Journal Service.
[    7.936587] systemd-journald[1052]: Received client request to flush runtime journal.
[    9.685098] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    9.686983] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.695697] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.700650] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    9.739249] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    9.746029] cfg80211: failed to load regulatory.db
[    9.770628] [drm] Initialized simpledrm 1.0.0 20200625 for 3fe5b000.framebuffer on minor 1
[    9.790760] simple-framebuffer 3fe5b000.framebuffer: [drm] fb1: simpledrmdrmfb frame buffer device
[    9.864251] mc: Linux media interface: v0.10
[    9.917899] Registered IR keymap rc-empty
[    9.920009] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
[    9.929183] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[    9.937096] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
[    9.945780] meson-ir c8100580.ir: receiver initialized
[    9.962352] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
[    9.965295] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
[    9.971768] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
[    9.977836] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
[    9.984072] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[    9.984090] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[    9.984662] lima d00c0000.gpu: bus rate = 166666667
[    9.985397] videodev: Linux video capture interface: v2.00
[   10.013279] meson8b-dwmac c9410000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   10.013684] lima d00c0000.gpu: mod rate = 24000000
[   10.013830] lima d00c0000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[   10.017427] [drm] Initialized lima 1.1.0 20191231 for d00c0000.gpu on minor 2
[   10.080268] meson8b-dwmac c9410000.ethernet eth0: PHY [stmmac-0:00] driver [ICPlus IP101G] (irq=POLL)
[   10.096950] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
[   10.100852] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
[   10.108118] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
[   10.211346] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   10.372561] bFWReady == _FALSE call reset 8051...
[   11.142176] zram: Added device: zram0
[   11.145656] zram: Added device: zram1
[   11.150928] zram: Added device: zram2
[   11.274998] zram0: detected capacity change from 0 to 947416
[   11.340924] Adding 473704k swap on /dev/zram0.  Priority:5 extents:1 across:473704k SS
[   11.594083] zram1: detected capacity change from 0 to 102400
[   12.715557] systemd-journald[1052]: Received client request to relinquish /var/log/journal/ab42acc046d84a19900de20222d9202b access.
[   13.182632] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   20.166974] systemd[1620]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 6789.505616] systemd-journald[1052]: Data hash table of /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal has a fill level at 75.0 (1585 of 2112 items, 1216512 file size, 767 bytes per hash table item), suggesting rotation.
[ 6789.537498] systemd-journald[1052]: /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal: Journal header limits reached or header out-of-date, rotating.
[15969.202471] systemd-journald[1052]: Data hash table of /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal has a fill level at 75.0 (1585 of 2112 items, 1216512 file size, 767 bytes per hash table item), suggesting rotation.
[15969.235722] systemd-journald[1052]: /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal: Journal header limits reached or header out-of-date, rotating.
[22270.598524] systemd-journald[1052]: Received SIGTERM from PID 1 (systemd).
[22270.599389] systemd[1]: Stopping systemd-journald.service - Journal Service...
[22270.613198] systemd[1]: systemd-journald.service: Deactivated successfully.
[22270.618983] systemd[1]: Stopped systemd-journald.service - Journal Service.
[22270.626007] systemd[1]: systemd-journald.service: Consumed 2.880s CPU time.
[22270.690584] systemd[1]: Starting systemd-journald.service - Journal Service...
[22270.766973] systemd[1]: Started systemd-journald.service - Journal Service.
[22270.805763] systemd-journald[3722]: Received client request to flush runtime journal.
[22271.035375] systemd-journald[3722]: Data hash table of /var/log/journal/ab42acc046d84a19900de20222d9202b/system.journal has a fill level at 142.3 (6477 of 4551 items, 2621440 file size, 404 bytes per hash table item), suggesting rotation.
[22271.056634] systemd-journald[3722]: /var/log/journal/ab42acc046d84a19900de20222d9202b/system.journal: Journal header limits reached or header out-of-date, rotating.
[22272.812907] systemd-journald[3722]: Received client request to relinquish /var/log/journal/ab42acc046d84a19900de20222d9202b access.
Hello again,
check the last rows of
journalctl -o short-precise -k -b -1
dic 31 00:00:02.512332 box systemd-journald[1052]: Received SIGTERM from PID 1 (systemd).
A midnight schedule?
dic 30 17:39:27.199678 box kernel: zram0: detected capacity change from 0 to 947416
dic 30 17:39:27.271739 box kernel: Adding 473704k swap on /dev/zram0.  Priority:5 extents:1 across:473704k SS
dic 30 17:39:27.519708 box kernel: zram1: detected capacity change from 0 to 102400
dic 30 17:39:28.918181 box systemd-journald[1052]: Received client request to relinquish /var/log/journal/ab42acc046d84a19900de20222d9202b access.
dic 30 17:39:29.115779 box kernel: meson8b-dwmac c9410000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
dic 30 17:39:36.099675 box kernel: systemd[1620]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
dic 30 19:42:01.900532 box systemd-journald[1052]: Data hash table of /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal has a fill level at 75.0 (1585 of 2112 items, 1216512 file size, 767 bytes per hash table item), suggesting rotation.
dic 30 19:42:01.901123 box systemd-journald[1052]: /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal: Journal header limits reached or header out-of-date, rotating.
dic 30 22:15:01.246424 box systemd-journald[1052]: Data hash table of /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal has a fill level at 75.0 (1585 of 2112 items, 1216512 file size, 767 bytes per hash table item), suggesting rotation.
dic 30 22:15:01.247068 box systemd-journald[1052]: /run/log/journal/ab42acc046d84a19900de20222d9202b/system.journal: Journal header limits reached or header out-of-date, rotating.
dic 31 00:00:02.512556 box systemd[1]: Stopping systemd-journald.service - Journal Service...
dic 31 00:00:02.512667 box systemd[1]: systemd-journald.service: Deactivated successfully.
dic 31 00:00:02.512739 box systemd[1]: Stopped systemd-journald.service - Journal Service.
dic 31 00:00:02.512815 box systemd[1]: systemd-journald.service: Consumed 2.880s CPU time.
dic 31 00:00:02.512898 box systemd[1]: Starting systemd-journald.service - Journal Service...
dic 31 00:00:02.519789 box systemd[1]: Started systemd-journald.service - Journal Service.
dic 31 00:00:04.536750 box systemd-journald[3722]: Received client request to flush runtime journal.
dic 31 00:00:04.537026 box systemd-journald[3722]: Data hash table of /var/log/journal/ab42acc046d84a19900de20222d9202b/system.journal has a fill level at 142.3 (6477 of 4551 items, 2621440 file size, 404 bytes per hash table item), suggesting rotation.
dic 31 00:00:04.537128 box systemd-journald[3722]: /var/log/journal/ab42acc046d84a19900de20222d9202b/system.journal: Journal header limits reached or header out-of-date, rotating.
I might have found something:
2025-01-07T06:57:03.303848+01:00 box kernel: [61203.449485] WARNING: CPU: 3 PID: 956 at kernel/workqueue.c:2557 process_one_work+0x5c/0x2a4
2025-01-07T06:57:03.303853+01:00 box kernel: [61203.456717] Modules linked in: lz4hc lz4 zram binfmt_misc nls_iso8859_1 8189es snd_soc_hdmi_codec snd_soc_core meson_vdec(C) snd_compress ac97_bus snd_pcm_dmaengine snd_pcm videobuf2_dma_contig snd_timer v4l2_mem2mem snd videobuf2_memops videobuf2_v4l2 soundcore videodev videobuf2_common lima mc gpu_sched meson_rng dw_hdmi_i2s_audio meson_ir rc_core simpledrm cfg80211 sg meson_gxbb_wdt scpi_hwmon drm_shmem_helper rfkill nvmem_meson_efuse dm_mod efi_pstore ip_tables x_tables autofs4 dwmac_generic icplus uas onboard_usb_hub dwmac_meson8b rtc_meson_vrtc
2025-01-07T06:57:03.303862+01:00 box kernel: [61203.512006] CPU: 3 PID: 956 Comm: kworker/3:1H Tainted: G         C         6.6.63-current-meson64 #1
2025-01-07T06:57:03.303868+01:00 box kernel: [61203.521146] Hardware name: Amlogic Meson GXBB P201 Development Board (DT)
2025-01-07T06:57:03.303871+01:00 box kernel: [61203.527881] Workqueue:  0x0 (kblockd)
2025-01-07T06:57:03.303906+01:00 box kernel: [61203.531497] pstate: 200000c5 (nzCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
2025-01-07T06:57:03.303911+01:00 box kernel: [61203.538395] pc : process_one_work+0x5c/0x2a4
2025-01-07T06:57:03.303914+01:00 box kernel: [61203.542622] lr : worker_thread+0x330/0x43c
2025-01-07T06:57:03.303919+01:00 box kernel: [61203.546675] sp : ffff800083e1bdb0
2025-01-07T06:57:03.303922+01:00 box kernel: [61203.549953] x29: ffff800083e1bdb0 x28: 0000000000000000 x27: ffff800081887000
2025-01-07T06:57:03.303925+01:00 box kernel: [61203.557025] x26: ffff00003b9bb100 x25: ffff00003b9bb0c0 x24: ffff800081a37808
2025-01-07T06:57:03.303929+01:00 box kernel: [61203.564098] x23: ffff8000818a4b48 x22: ffff00003ebf5130 x21: ffff00000139d600
2025-01-07T06:57:03.303932+01:00 box kernel: [61203.571171] x20: ffff000001c25330 x19: ffff00003b9bb0c0 x18: ffff000003b63620
2025-01-07T06:57:03.303935+01:00 box kernel: [61203.578243] x17: 0000000000000000 x16: 00000000000007ff x15: 0000000000000001
2025-01-07T06:57:03.303938+01:00 box kernel: [61203.585315] x14: ffff00003ebf5500 x13: 0000000000000002 x12: 0000000000000000
2025-01-07T06:57:03.303941+01:00 box kernel: [61203.592388] x11: 0000000000000001 x10: 0000000000000aa0 x9 : ffff800083e1bd20
2025-01-07T06:57:03.303945+01:00 box kernel: [61203.599460] x8 : ffff00000278c700 x7 : ffff00003ebf5500 x6 : ffff00003ebf5130
2025-01-07T06:57:03.303948+01:00 box kernel: [61203.606533] x5 : 00000000410fd030 x4 : ffff00003ebf5158 x3 : ffff00003ebf5150
2025-01-07T06:57:03.303951+01:00 box kernel: [61203.613605] x2 : ffff7fffbd62f000 x1 : 0000000000000002 x0 : 0000000000000003
2025-01-07T06:57:03.303954+01:00 box kernel: [61203.620679] Call trace:
2025-01-07T06:57:03.303957+01:00 box kernel: [61203.623094]  process_one_work+0x5c/0x2a4
2025-01-07T06:57:03.303960+01:00 box kernel: [61203.626975]  worker_thread+0x330/0x43c
2025-01-07T06:57:03.303963+01:00 box kernel: [61203.630683]  kthread+0x118/0x11c
2025-01-07T06:57:03.303966+01:00 box kernel: [61203.633874]  ret_from_fork+0x10/0x20
2025-01-07T06:57:03.303969+01:00 box kernel: [61203.637412] ---[ end trace 0000000000000000 ]---
2025-01-07T06:58:01.814472+01:00 box kernel: [61262.073890] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
2025-01-07T06:58:01.814517+01:00 box kernel: [61262.075947] rcu:        1-...0: (10 ticks this GP) idle=450c/1/0x4000000000000000 softirq=75865/75865 fqs=7455
2025-01-07T06:58:01.814522+01:00 box kernel: [61262.085346] rcu:        (detected by 3, t=15003 jiffies, g=288557, q=105 ncpus=4)
2025-01-07T06:58:01.814526+01:00 box kernel: [61262.092245] Task dump for CPU 1:
2025-01-07T06:58:01.814529+01:00 box kernel: [61262.095436] task:systemd         state:R  running task     stack:0     pid:1     ppid:0      flags:0x00000002
2025-01-07T06:58:01.814532+01:00 box kernel: [61262.105269] Call trace:
2025-01-07T06:58:01.814536+01:00 box kernel: [61262.107684]  __switch_to+0xdc/0x13c
2025-01-07T06:58:01.814564+01:00 box kernel: [61262.111133]  kfree+0x58/0x70
2025-01-07T06:58:01.814569+01:00 box kernel: [61262.113979]  proc_cgroup_show+0x240/0x36c
2025-01-07T06:58:01.814572+01:00 box kernel: [61262.117946]  proc_single_show+0x60/0x118
2025-01-07T06:58:01.814575+01:00 box kernel: [61262.121828]  seq_read_iter+0x46c/0x4d8
2025-01-07T06:58:01.814579+01:00 box kernel: [61262.125536]  do_wp_page+0x6f0/0xd64
2025-01-07T06:58:01.814582+01:00 box kernel: [61262.128986]  __handle_mm_fault+0x898/0x1014
2025-01-07T06:58:01.814586+01:00 box kernel: [61262.133126]  handle_mm_fault+0xe8/0x2d4
2025-01-07T06:58:01.814589+01:00 box kernel: [61262.136921]  do_page_fault+0x194/0x4c4
2025-01-07T06:58:01.814592+01:00 box kernel: [61262.140630]  do_mem_abort+0x44/0x94
2025-01-07T06:58:01.814595+01:00 box kernel: [61262.144080]  el0_da+0x30/0x88
2025-01-07T06:58:01.814599+01:00 box kernel: [61262.147013]  el0t_64_sync_handler+0xe4/0x158
2025-01-07T06:58:01.814602+01:00 box kernel: [61262.151239]  el0t_64_sync+0x190/0x194
And then it goes on like this for 2.5 hours logging something like this every 3 minutes:
2025-01-07T09:31:06.914631+01:00 box kernel: [70447.528332] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
2025-01-07T09:31:06.914675+01:00 box kernel: [70447.529930] rcu:        1-...0: (10 ticks this GP) idle=450c/1/0x4000000000000000 softirq=75865/75865 fqs=1148550
2025-01-07T09:31:06.914679+01:00 box kernel: [70447.539587] rcu:        (detected by 2, t=2311279 jiffies, g=288557, q=11620 ncpus=4)
2025-01-07T09:31:06.914684+01:00 box kernel: [70447.546831] Task dump for CPU 1:
2025-01-07T09:31:06.914688+01:00 box kernel: [70447.550022] task:systemd         state:R  running task     stack:0     pid:1     ppid:0      flags:0x00000002
2025-01-07T09:31:06.914692+01:00 box kernel: [70447.559856] Call trace:
2025-01-07T09:31:06.914695+01:00 box kernel: [70447.562270]  __switch_to+0xdc/0x13c
2025-01-07T09:31:06.914723+01:00 box kernel: [70447.565720]  kfree+0x58/0x70
2025-01-07T09:31:06.914727+01:00 box kernel: [70447.568566]  proc_cgroup_show+0x240/0x36c
2025-01-07T09:31:06.914731+01:00 box kernel: [70447.572533]  proc_single_show+0x60/0x118
2025-01-07T09:31:06.914734+01:00 box kernel: [70447.576414]  seq_read_iter+0x46c/0x4d8
2025-01-07T09:31:06.914737+01:00 box kernel: [70447.580123]  do_wp_page+0x6f0/0xd64
2025-01-07T09:31:06.914741+01:00 box kernel: [70447.583573]  __handle_mm_fault+0x898/0x1014
2025-01-07T09:31:06.914744+01:00 box kernel: [70447.587713]  handle_mm_fault+0xe8/0x2d4
2025-01-07T09:31:06.914747+01:00 box kernel: [70447.591508]  do_page_fault+0x194/0x4c4
2025-01-07T09:31:06.914750+01:00 box kernel: [70447.595217]  do_mem_abort+0x44/0x94
2025-01-07T09:31:06.914754+01:00 box kernel: [70447.598667]  el0_da+0x30/0x88
2025-01-07T09:31:06.914757+01:00 box kernel: [70447.601599]  el0t_64_sync_handler+0xe4/0x158
2025-01-07T09:31:06.914760+01:00 box kernel: [70447.605826]  el0t_64_sync+0x190/0x194
Any ideas on what to do now? :)
