g2t Posted December 30, 2024 Posted December 30, 2024 (edited) Hi, I have installed the latest image "Minimal/IOT images with Armbian Linux v6.12" with the mainline Kernel. Many thanks @ColorfulRhino , @amazingfate and many others for their hard work. I have a board with 32GB RAM and 4x NVMe and it is working with HDMI, USB and network. I have installed XFCE on top by my own. Some parts currently not working (what I have seen so far): * second HDMI * HDMI audio * sensor controlled fan speed This seems to be on the roadmap for 2025 for the upstream Kernel. For the fan control I currently use my own overlay and want to share it. /dts-v1/; /plugin/; / { /* our pwm-fan comes with 6 cooling levels (0-5) in relation to 255 <0 50 80 120 160 220> */ /* this overlay use the sensors of big core 0 to control cooling by the fan */ /* add new trips for active cooling */ fragment@0 { target-path = "/thermal-zones/bigcore0-thermal/trips"; __overlay__ { bigcore0-active1 { /* 55 degree with hysteresis of 5 deg */ temperature = <55000>; hysteresis = <5000>; type = "active"; // internal phandles use a small integer to be able to reference phandle = <0x00000001>; }; bigcore0-active2 { /* 60 degree with hysteresis of 2 deg */ temperature = <60000>; hysteresis = <2000>; type = "active"; // internal phandles use a small integer to be able to reference phandle = <0x00000002>; }; }; }; /* add cooling maps to use the new trips by the pwm-fan with level 0-5 */ fragment@1 { target-path = "/thermal-zones/bigcore0-thermal/cooling-maps"; __overlay__ { map1 { trip = <0x00000001>; cooling-device = <0xffffffff 0 1>; }; map2 { trip = <0x00000002>; cooling-device = <0xffffffff 2 5>; }; }; }; /* we need to poll, because in interrupt mode the fan will not stop */ /* alternatively we can use type="passive", a poll interval of 250 ms is already defined for passive */ fragment@2 { target-path = "/thermal-zones/bigcore0-thermal"; __overlay__ { /* for active cooling, in milliseconds */ polling-delay = <2000>; }; }; /* adjust the original fan levels <0 50 80 120 160 220> a bit */ /* the fan starts rotating at 40-45, 45 is sufficient to keep <50°C at normal operation */ fragment@3 { target = <0xffffffff>; __overlay__ { cooling-levels = <0 45 80 120 160 255>; }; }; __fixups__ { fan = "/fragment@1/__overlay__/map1:cooling-device:0", "/fragment@1/__overlay__/map2:cooling-device:0", "/fragment@3:target:0"; }; // to adjust finally the internal references __local_fixups__ { fragment@1 { __overlay__ { map1 { trip = <0x00000000>; }; map2 { trip = <0x00000000>; }; }; }; }; }; Edited December 30, 2024 by g2t 0 Quote
Vijay Gill Posted January 9, 2025 Posted January 9, 2025 (edited) @g2t - thanks for sharing. Just curious what temperatures do you see with and without fan? I have this NAS running in the metallic case they sell on aliexpress. I see 68-70 °C even when CPU is idle. I am planning to change the heatsink but I thought of asking here first. Edited January 9, 2025 by Vijay Gill 0 Quote
g2t Posted January 9, 2025 Author Posted January 9, 2025 Hi @Vijay Gill, at the moment I start a gentoo rfs after the boot with armbian Kernel. Also I currently use a vendor Kernel build by my own with the armbian tool chain (took < 4min on the cm3588 system without Docker). So I can not say anything about the "idle-ness" of the mainline armbian Kernel and armbian rfs. At least for my system I think it would not go about 50-60°C when idle without the fan. This is my assumption because after the monitors (2 monitors possible with vendor Kernel) go to standby mode, the fan stops forever. But I have closed the case at the moment, so I can not simply disconnect the fan for an exact measurement. Do you have checked your system with "top" or another tool? 0 Quote
Vijay Gill Posted January 9, 2025 Posted January 9, 2025 (edited) Hi @g2t, thanks for your reply. Stopped fan is as good as disconnected one, in my opinion. Also 0-5% CPU is idle for me. My CPU does not do much most of the time for now. (I am planning to migrate my home assistant and about 15 more docker containers from my existing raspberry pi based NAS to this one). So, I take it your system is 50-60°C when idle. It seems I will have to change the heatsink to a better one. I took mine off today and I suspect the blue "chewing-gum" they put in there was not good enough. I do not have a thermal pad thick enough for replacement as the gap between the chip and heatsink seems to be be a bit larger. I put another one I had (much smaller than the original) but better contact and I see the same temperatures. So I have a feeling that I will see better results with a larger cooler and better contact. I am planning to pick up this one - https://ie.rs-online.com/web/p/heatsinks/5040772 Edited January 9, 2025 by Vijay Gill 0 Quote
Vijay Gill Posted March 6, 2025 Posted March 6, 2025 (edited) @g2t Just sharing my build here - I reverted to stock heatsink but moved the setup into a 3d printed case. The metallic case being sold all over aliexpress is useless (for me). The new case has 80mm noctua fan at the top. I am running it using the fan header (that zh1.5 one) on the board itself. The kernel seems to have support for controlling the PWM levels from 0 (off) to 5. The fan is really inaudible at levels 1-3. At 4 and 5 is it kind of audible but not annoying. In last 24 hours I did not need going to any level above 1 even while running stress command with all cores going 100%. The CPU temps maxed out at 58 degrees. Edited March 7, 2025 by Vijay Gill 0 Quote
gpio123 Posted April 1, 2025 Posted April 1, 2025 @Vijay Gill is that case design available online somewhere? 0 Quote
csa1999 Posted April 12, 2025 Posted April 12, 2025 @g2t - the overlay you posted wasn't compatible with my 6.1.99-vendor-rk35xx kernel, so I changed it a bit until it started to work. /dts-v1/; /plugin/; / { /* Add new thermal trip points for active cooling */ fragment@0 { target-path = "/thermal-zones/bigcore0-thermal/trips"; __overlay__ { bigcore0-active1 { /* 55 degree with hysteresis of 5 deg */ temperature = <55000>; hysteresis = <5000>; type = "active"; phandle = <0x1001>; }; bigcore0-active2 { /* 60 degree with hysteresis of 2 deg */ temperature = <60000>; hysteresis = <2000>; type = "active"; phandle = <0x1002>; }; }; }; /* Set polling delay for active cooling */ fragment@1 { target-path = "/thermal-zones/bigcore0-thermal"; __overlay__ { /* for active cooling, in milliseconds */ polling-delay = <2000>; }; }; /* Enable PWM fan and adjust cooling levels */ fragment@2 { target-path = "/pwm-fan"; __overlay__ { status = "okay"; cooling-levels = <0 45 80 120 160 255>; }; }; /* Add cooling maps to associate thermal trips with fan cooling levels */ fragment@3 { target-path = "/thermal-zones/bigcore0-thermal"; __overlay__ { cooling-maps { map1 { trip = <0x1001>; cooling-device = <&fan 0 1>; }; map2 { trip = <0x1002>; cooling-device = <&fan 2 5>; }; }; }; }; __symbols__ { fan = "/pwm-fan"; }; }; 0 Quote
Vijay Gill Posted April 18, 2025 Posted April 18, 2025 @gpio123 yes it is. See https://github.com/Nighthater/CM3588-NAS-Case. 0 Quote
giuseppe mastrodonato Posted January 19 Posted January 19 Hi everyone, and sorry for my poor English. I'd like to enable PWM on my CM3588 nanoPC with the latest Armbian Trixie version. Can anyone who's managed to get the PWM working properly tell me which pin to connect the PWM signal to and what exactly to do to enable it? Thanks to anyone who replies. 0 Quote
