Lele Zhang Posted January 1, 2025 Posted January 1, 2025 Armbianmonitor: https://paste.next.armbian.com/dicejuhijo Hi, I'm running Ambian 24.11.2 Noble Genome version on OrangePi 5 Plus in my nvme drive. I want to change my system language to Chinese simplified. However, when I select 'Chinese simplified' in 'Settings -> System -> Region & Language -> Manage Installed Languages -> Install/Remove Languages' and click 'Apply'. It says: 'software database is broken. It is impossible to install or remove any software. Please use the software manager "Synaptic" or run "sudo apt-get install -f " in terminal to fix this issue at first.' I did tried to run synaptic with sudo and clicked 'Fix Broken Packages' and 'Reload'. It says 0 is broken, 0 to install/upgrade and 0 to remove. I also tried to run "sudo apt-get install -f ". It says: ----------------- Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. ------------------ However, the problem persists. Interestingly, I found that French language can be installed properly via the same method. But neither simplified or traditional Chinese can be installed. I'm out of my wits. I would really appreciate any help to narrow the question! 0 Quote
