Meestor_X Posted January 6, 2025 Posted January 6, 2025 motd is no longer showing on boot with my rockpi-s and rock s0. (same cpu) I feel like this started when I updated from 24.8.3 to 24.11.1 Anyone else having this problem? This looks suspect... root@rock-s0:/etc# cat /etc/motd cat: /etc/motd: No such file or directory root@rock-s0:/etc# cat /var/run/motd cat: /var/run/motd: No such file or directory root@rock-s0:/etc# cd /etc/ root@rock-s0:/etc# ls -l motd lrwxrwxrwx 1 root root 13 Nov 24 15:27 motd -> /var/run/motd root@rock-s0:/etc# cd /var/run root@rock-s0:/var/run# ls -l motd ls: cannot access 'motd': No such file or directory 0 Quote
Solution Meestor_X Posted January 6, 2025 Author Solution Posted January 6, 2025 Here's the fix if anyone hasn't figured it out... sudo chmod +x /etc/update-motd.d/* 0 Quote
konsD Posted March 15, 2025 Posted March 15, 2025 06.01.2025 в 20:22, Meestor_X сказал: motd is no longer showing on boot Hi. Do you see it when connected via ssh? 0 Quote
