Mark Waples Posted January 12, 2025 Posted January 12, 2025 Hi there, Forgive me but I am a novice in Armbian. What I would like to do is install armbian on the T95Max box I have purchased. I have attached a pic of the Box and it's specs. I have tried to "upgrade" using the SD method but couldn't make that recognise the SD card even with the original firmware "T95max-H618-A9.img" that I sourced using Google. I have also tried to get the T95 Max recognised via the USB method but the box wasn't even recognised using that method either. I used the "Universal_ADB_Driver_v6.0" drivers but that made no difference. If I could get the correct method sorted and an upgradeable firmware for Ambian that would be a great help. I can compile the firmware if needed but I am unsure of what Ambian image would be the best starting point. Any help would be gratefully received. TIA 0 Quote
Nick A Posted January 12, 2025 Posted January 12, 2025 (edited) Hi Mark, Try this image. First extract the image. Then use balenaEtcher software to write the image onto your SD card. A toothpick can be used to trigger FEL mode on an TX95 Max by pressing the FEL button on the PCB with the non-conductive tool. The FEL button is located inside the 3.5 mm headphone socket. To trigger FEL mode, press the button while the device is booting. https://etcher.balena.io/#download-etcher https://github.com/NickAlilovic/build/releases/download/20241125/Armbian-20241125-unofficial_24.11.0-trunk_Transpeed-8k618-t_bookworm_edge_6.10.10_xfce_desktop.tar.gz Edited January 12, 2025 by Nick A 1 Quote
Mark Waples Posted January 13, 2025 Author Posted January 13, 2025 (edited) Hi Nick, Thank you for your reply. I have tried the image and have successfully loaded ARMBIAN from the SD so thank you for that! A lifesaver! It hasn't overwritten the EMMC and currently only runs just from the SD which at the moment is not a bad thing while testing. I guess at some point I would want the box to boot armbian from the EMCC - I am not sure If that's possible. I was wondering if the Armbian image could support the boxes inbuilt WIFI? It works on ethernet and a USB Wifi Dongle but not the inbuilt wifi. Lastly I only want to run one software package when the box boots, is it a case of just adding the package by the normal means (Curl)? And then If I wish to repeat the exercise for another box I can just image the SD and use that to create a new box? Kind regards, Mark Edited January 13, 2025 by Mark Waples updated info 0 Quote
Nick A Posted January 13, 2025 Posted January 13, 2025 To get wifi working we need to figure out which wifi chip your box has. The kernel might have already detected your wifi chip but you need to install the proper firmware. Can you post a copy of your dmesg. 0 Quote
Mark Waples Posted January 13, 2025 Author Posted January 13, 2025 (edited) 1 hour ago, Nick A said: To get wifi working we need to figure out which wifi chip your box has. The kernel might have already detected your wifi chip but you need to install the proper firmware. Can you post a copy of your dmesg. Hi Nick, I have attached the dsmeg file as requested: dmesg.txt I guess its all the following that are not working Wifi HDMI Audio & SPDIF IR Remote Not sure about the following: (Untested) Ethernet Bluetooth OpenGL & Hardware Video Decoding Kind regards, Mark ps: I forgot to say: is it safe to sudo apt update ; sudo apt upgrade -y As I am not sure if this will break the custom image?? Edited January 13, 2025 by Mark Waples 0 Quote
Nick A Posted January 13, 2025 Posted January 13, 2025 (edited) Wifi: I don't see anything in your dmesg that helps. You need to open your box and take a picture of the wifi chip. HDMI audio: I think you need to switch the pulseaudio output device. It's probably set to your AV port right now. IR remote: sudo apt update ; sudo apt upgrade -y Yes it will break the custom kernel. You need to block kernel updates with the armbian config tool. You should read this thread. You'll find a lot of infomation here. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/18/ Edited January 13, 2025 by Nick A 0 Quote
Mark Waples Posted January 13, 2025 Author Posted January 13, 2025 (edited) Hi Nick, the wifi Chip is as follows: SV6256P Single-Chip Dual Band 802.11 a/b/g/n MAC/BB/Radio with USB/SDIO Interface Supports calibration algorithm to handle no-idealities effects from CMOS RF block WFA features: WEP/TKIP/WPA/WPA2; WMM/WMM PS STBC in RX mode A-MPDU Tx & Rx Support immediate Block-Ack AP/STA mode: Soft-AP Single power supply,type 3.3V and the Bluetooth Chip is as follows: BR8052A01 And the LED driver chip is a AIP650E0 If it helps others I will post some images of both sides of the PCB Mark Edited January 13, 2025 by Mark Waples 0 Quote
Mark Waples Posted January 13, 2025 Author Posted January 13, 2025 Hi Nick, Images of PCB Mark 0 Quote
Nick A Posted January 13, 2025 Posted January 13, 2025 (edited) I haven't seen any mainline linux drivers for SV6256P chip. Edited January 13, 2025 by Nick A 0 Quote
Mark Waples Posted January 13, 2025 Author Posted January 13, 2025 Nick, appreciated - seems this box is not well supported in linux well the wi-fi anyway. Until linux drivers come along in the future, there must be a better box that has full linux/Armbian support? Any recomendations please? Mark 0 Quote
Nick A Posted January 13, 2025 Posted January 13, 2025 This is the box I'm using.. Everything works. Bluetooth still has some bugs. (Works only after I enable it in android). https://linux-sunxi.org/Transpeed_8K618-T 0 Quote
Mark Waples Posted January 14, 2025 Author Posted January 14, 2025 (edited) Thanks Nick, grateful for the recommendation. Can you please tell me if your image supports Realtek 8821CU - if not is it possible to add it? I have one of these dual bluetooth and wifi. Interesting that windows reports it as Realtek 8821CU but Armbian reports it as a Realtek 8188GU UPDATE: I noticed that the device was in CDmode using the command lsusb so I installed modeswitch sudo apt install usb-modeswitch usb-modeswitch-data And that's it fully working wifi and bluetooth. No other configuration required. Edited January 14, 2025 by Mark Waples 0 Quote
Mark Waples Posted January 14, 2025 Author Posted January 14, 2025 Hi Nick, I am making progress so thank you for your assistance. Just one more thing and I promise I will leave you alone I can't seem to get a user to automtically login. I edited the lightdmf.config with the following line: autologin-user=username-here But that didn't work I only have one user apart from root. My single user does not have a password and I am not sure that is an issue. Kind regards, Mark 0 Quote
Mark Waples Posted January 14, 2025 Author Posted January 14, 2025 Hi Nick, Ignore the Auto-login Issue. I followed these instructions and it worked perfectly https://forum.armbian.com/topic/37238-skip-login-automatically/#findComment-187066 0 Quote
Mark Waples Posted January 15, 2025 Author Posted January 15, 2025 (edited) Getting there... Trying to get the openvfd service to run trying to follow these instructions... Jan 15 14:06:29 transpeed-8k618-t systemd[1]: Started openvfd.service - OpenVFD Service. Jan 15 14:06:29 transpeed-8k618-t sh[2627]: modprobe: FATAL: Module openvfd not found in directory /lib/modules/6.10.10-edge-sunxi64 Jan 15 14:06:29 transpeed-8k618-t sh[2628]: Open device failed. Jan 15 14:06:29 transpeed-8k618-t sh[2628]: : No such file or directory Jan 15 14:06:29 transpeed-8k618-t systemd[1]: openvfd.service: Main process exited, code=exited, status=1/FAILURE Jan 15 14:06:29 transpeed-8k618-t rmmod[2629]: rmmod: ERROR: Module openvfd is not currently loaded Jan 15 14:06:29 transpeed-8k618-t systemd[1]: openvfd.service: Failed with result 'exit-code'. OK I tried to make the modules but get the following error root@transpeed-8k618-t:~/linux_openvfd/driver# make -j 4 make -C /lib/modules/6.10.10-edge-sunxi64/build M=/root/linux_openvfd/driver modules make[1]: Entering directory '/usr/lib/modules/6.10.10-edge-sunxi64/build' make[1]: *** No rule to make target 'modules'. Stop. make[1]: Leaving directory '/usr/lib/modules/6.10.10-edge-sunxi64/build' make: *** [Makefile:5: modules] Error 2 root@transpeed-8k618-t:~/linux_openvfd/driver# I have installed the headers using the Armbian Config Tool and rebooted And retried but no go! Still none the wiser Any suggestions most welcome... Edited January 15, 2025 by Mark Waples 0 Quote
Nick A Posted January 16, 2025 Posted January 16, 2025 You need the header files from my build.. https://github.com/NickAlilovic/build/releases/tag/20241125 0 Quote
Mark Waples Posted January 16, 2025 Author Posted January 16, 2025 (edited) Hi Alex, thanks again - I am learning fast. I have installed your headers - Git clone timed out so had to manually copy the header deb file to my /root git clone git://github.com/NickAlilovic/build/releases/download/20241125/linux-headers-edge-sunxi64_24.11.0-trunk_arm64__6.10.10-S049b-D2d3c-P228a-C1adfH5c21-HK01ba-Vc222-Ba3b7-R448a.deb And installed them using the command: sudo dpkg -i linux-headers-edge-sunxi64_24.11.0-trunk_arm64__6.10.10-S049b-D2d3c-P228a-C1adfH5c21-HK01ba-Vc222-Ba3b7-R448a.deb When using the command make -j 4 from the /root/linux_openvfd/driver folder I get the following error: root@transpeed-8k618-t:~/linux_openvfd/driver# make -j 4 make -C /lib/modules/6.10.10-edge-sunxi64/build M=/root/linux_openvfd/driver modules make[1]: Entering directory '/usr/lib/modules/6.10.10-edge-sunxi64/build' make[1]: *** No rule to make target 'modules'. Stop. make[1]: Leaving directory '/usr/lib/modules/6.10.10-edge-sunxi64/build' make: *** [Makefile:5: modules] Error 2 root@transpeed-8k618-t:~/linux_openvfd/driver# For info I am trying to follow MMorales info. unpack the attached file to root dir / cd /linux_openvfd cp openvfd.dts /boot/dtb/allwinner/overlay/ armbian-add-overlay /boot/dtb/allwinner/overlay/openvfd.dts reboot ln -sf /boot/System.map-$(uname -r) /lib/modules/$(uname -r)/build/System.map cd cd /linux_openvfd/driver make -j 4 depmod -a make modules_install modprobe openvfd cd .. chmod +x OpenVFDService cp OpenVFDService /usr/sbin/ cp openvfd.service /etc/systemd/system/openvfd.service #apt install python3-psutil systemctl enable openvfd.service systemctl start openvfd.service After this, openvfd is working but if you want my scroll.py as a service uncomment in openvfd.service and comment the existing one. #ExecStart=/bin/sh -c '[ `cat /proc/device-tree/openvfd/compatible` = "open,vfd" ] && /sbin/modprobe openvfd; python3 /linux_openvfd/scroll.py' Kind regards, Mark Edited January 17, 2025 by Mark Waples 0 Quote
Mark Waples Posted February 10, 2025 Author Posted February 10, 2025 I never did resolve this. Might just revisit this at a later date. So close but not close enough lol I took the easy option and went for a pi 2 zero for my project which is a shame but when you live on the edge these things happen 0 Quote
Mark Waples Posted February 11, 2025 Author Posted February 11, 2025 At last I have linux_openvfd working although some of the charaters are upside down lol the Makefile was incorrect and should have been as follows: ifeq ($(KERNELRELEASE),) PWD = $(shell pwd) KERNELDIR = /lib/modules/`uname -r`/build modules: $(MAKE) -C $(KERNELDIR) M=$(PWD) modules modules_install: $(MAKE) -C $(KERNELDIR) M=$(PWD) modules_install clean: rm -rf *.o *.ko .tmp_versions *.mod.c modules.order Module.symvers ssd253x-ts.* else obj-m := openvfd.o openvfd-objs += protocols/i2c_sw.o openvfd-objs += protocols/i2c_hw.o openvfd-objs += protocols/spi_sw.o openvfd-objs += controllers/dummy.o openvfd-objs += controllers/seg7_ctrl.o openvfd-objs += controllers/fd628.o openvfd-objs += controllers/fd650.o openvfd-objs += controllers/hd44780.o openvfd-objs += controllers/gfx_mono_ctrl.o openvfd-objs += controllers/ssd1306.o openvfd-objs += controllers/pcd8544.o openvfd-objs += controllers/il3829.o openvfd-objs += openvfd_drv.o endif I got this information from here: https://github.com/bk3a12/openvfd_enable_for_tx3_mini/tree/main Makefile.txt 0 Quote
Mark Waples Posted February 11, 2025 Author Posted February 11, 2025 According to instructions: Place your vfd.conf into /storage/.config folder. Am I mssing something? Where is the /storage directory? Sorry for being so dumb - does anyone know where the vfd.conf files should go? 0 Quote
Mark Waples Posted February 11, 2025 Author Posted February 11, 2025 Hmm the plot thickens dmesg | grep Open - gives me this - so it's not finding the vfd.conf file and is looking in the Device Tree for instructions as a fallback - so where does this vfd.conf file go? [ 14.228662] OpenVFD: Version: V1.4.4 [ 14.228681] OpenVFD: vfd_gpio_clk: Empty. [ 14.228686] OpenVFD: vfd_gpio_dat: Empty. [ 14.228691] OpenVFD: vfd_gpio_stb: Empty. [ 14.228698] OpenVFD: vfd_gpio0: #0 = 0x00; #1 = 0x00; #2 = 0xFF; [ 14.228704] OpenVFD: vfd_gpio1: #0 = 0x00; #1 = 0x00; #2 = 0xFF; [ 14.228711] OpenVFD: vfd_gpio2: #0 = 0x00; #1 = 0x00; #2 = 0xFF; [ 14.228718] OpenVFD: vfd_gpio3: #0 = 0x00; #1 = 0x00; #2 = 0xFF; [ 14.228724] OpenVFD: vfd_gpio_protocol: #0 = 0x00; #1 = 0x00; [ 14.228728] OpenVFD: vfd_chars: Empty. [ 14.228733] OpenVFD: vfd_dot_bits: Empty. [ 14.228738] OpenVFD: vfd_display_type: Empty. [ 14.228749] OpenVFD: Detected gpio chips: 300b000.pinctrl, 7022000.pinctrl. [ 14.228753] OpenVFD: Failed to verify VFD configuration file, attempt using device tree as fallback. [ 14.237971] OpenVFD: openvfd_gpio_clk: pin = 267, flags = 0x00 [ 14.237998] OpenVFD: openvfd_gpio_dat: pin = 268, flags = 0x00 [ 14.238004] OpenVFD: openvfd_gpio_stb pin entry not found [ 14.238009] OpenVFD: openvfd_gpio0 pin entry not found [ 14.238013] OpenVFD: openvfd_gpio1 pin entry not found [ 14.238017] OpenVFD: openvfd_gpio2 pin entry not found [ 14.238021] OpenVFD: openvfd_gpio3 pin entry not found [ 14.238025] OpenVFD: chars_prop = 00000000a90cb56d [ 14.238033] OpenVFD: chars_prop->length = 5 [ 14.238036] OpenVFD: char #0: 2 [ 14.238040] OpenVFD: char #1: 1 [ 14.238044] OpenVFD: char #2: 2 [ 14.238048] OpenVFD: char #3: 3 [ 14.238052] OpenVFD: char #4: 4 [ 14.238057] OpenVFD: dot_bits_prop = 000000008d579c57 [ 14.238061] OpenVFD: dot_bits_prop->length = 7 [ 14.238065] OpenVFD: dot_bit #0: 0 [ 14.238070] OpenVFD: dot_bit #1: 1 [ 14.238073] OpenVFD: dot_bit #2: 3 [ 14.238077] OpenVFD: dot_bit #3: 2 [ 14.238081] OpenVFD: dot_bit #4: 4 [ 14.238085] OpenVFD: dot_bit #5: 5 [ 14.238089] OpenVFD: dot_bit #6: 6 [ 14.238094] OpenVFD: display.type = 0, display.controller = 3, pdata->dev->dtb_active.display.flags = 0x00 [ 14.238531] OpenVFD: Select FD650 controller [ 14.238612] OpenVFD: SW I2C interface intialized (address = 0x0000 (N/A), MSB mode, pull-ups off) 0 Quote
Nick A Posted February 11, 2025 Posted February 11, 2025 (edited) Quote At last I have linux_openvfd working although some of the charaters are upside down lol https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/#findComment-207680 Using MMorales openvfd scripts I don't remember needing vdf.conf. In openvfd.service you can remove "#" infront of ExecStart=/bin/sh -c '[ `cat /proc/device-tree/openvfd/compatible` = "open,vfd" ] && /sbin/modprobe openvfd; python3 /linux_openvfd/scroll.py' then edit the scroll.py script with your custom settings. Remember to add '#' in the second ExecStart. [Unit] Description=OpenVFD Service ConditionPathExists=/proc/device-tree/openvfd/ [Service] #ExecStart=/bin/sh -c '[ `cat /proc/device-tree/openvfd/compatible` = "open,vfd" ] && /sbin/modprobe openvfd; python3 /linux_openvfd/scroll.py' ExecStart=/bin/sh -c '[ `cat /proc/device-tree/openvfd/compatible` = "open,vfd" ] && /sbin/modprobe openvfd; /usr/sbin/OpenVFDService' ExecStop=/bin/kill -TERM $MAINPID ExecStopPost=-/usr/sbin/rmmod openvfd RemainAfterExit=yes [Install] WantedBy=basic.target Edited February 11, 2025 by Nick A 0 Quote
Mark Waples Posted February 14, 2025 Author Posted February 14, 2025 (edited) Hi Nick, I attempted to modify the /boot/dtb/allwinner/overlay/openvfd.dts as the following two ways and still the characters are upside down. openvfd.dts for Tanix /dts-v1/; /plugin/; / { fragment@0 { target-path = "/"; __overlay__ { openvfd { compatible = "open,vfd"; dev_name = "openvfd"; openvfd_gpio_clk = <&pio 8 11 6>; openvfd_gpio_dat = <&pio 8 12 6>; vfd_gpio_chip_name = "0300b000.pinctrl"; openvfd_chars = [02 04 03 02 01]; openvfd_dot_bits = [00 01 03 02 04 05 06]; openvfd_display_type = <0x03000001>; status = "okay"; }; }; }; }; and this one: openvfd.dts for Vontar (Transpeed) /dts-v1/; /plugin/; / { fragment@0 { target-path = "/"; __overlay__ { openvfd { compatible = "open,vfd"; dev_name = "openvfd"; openvfd_gpio_clk = <&pio 8 11 0>; openvfd_gpio_dat = <&pio 8 12 0>; vfd_gpio_chip_name = "0300b000.pinctrl"; openvfd_chars = [02 01 02 03 04]; openvfd_dot_bits = [00 01 03 02 04 05 06]; openvfd_display_type = <0x03000000>; status = "okay"; }; }; }; }; I still have the display upside down - and no colon between the digits and on the right I get a constantly flahing network symbol I have a feeling I am barking up the wrong tree by editing this file - it makes no difference. Kind regards, Mark Edited February 14, 2025 by Mark Waples 0 Quote
Nick A Posted February 15, 2025 Posted February 15, 2025 openvfd,display-type usually is 00 (normal) or 01 if your display translate by 180 degrees (ie: characters are flipped down and specular) Maybe you can find more info here.. https://discourse.coreelec.org/t/how-to-configure-vfd/427/702?page=34 0 Quote
Mark Waples Posted February 15, 2025 Author Posted February 15, 2025 NIck, Thank you for the reply and your assistance, but first I need to establish what file the OpenVFD service is using for it's configuration. There are so many posts with conflicting methods and I have tried them all but to no avail. What a mess! So if anyone can tell me how to find the configuration file I am stumped. As I said this is new to me so I am learning on the job so to speak. Kind regards, Mark 0 Quote
Nick A Posted February 15, 2025 Posted February 15, 2025 (edited) [ 14.228753] OpenVFD: Failed to verify VFD configuration file, attempt using device tree as fallback. Your openvfd is using the device tree as the configuration file since it cannot find the configuration file vfd.conf. You can edit your device tree overlay or you would need to create a /storage/.config/ directory and put your vfd.conf inside. You’ll need root permission to create the directories and file. Here you can find example vfd.conf files. https://github.com/arthur-liberman/vfd-configurations/ You can also try running this command for help. OpenVFDService --help Then there's also the openvfd.service. This runs OpenVFDService everytime your linux server boots. openvfd.service Other ways of controlling the LED's. You can put these commands in openvfd.service if needed. https://github.com/arthur-liberman/linux_openvfd/blob/9264588ba27a964a1e56346202901dd17f9e133d/led_control.txt Have you tried extracting your dts? you might find your android original openvfd device tree settings there. Edited February 15, 2025 by Nick A 0 Quote
jock Posted February 15, 2025 Posted February 15, 2025 Not to hijack the thread, but there is a much better alternative driver rather than OpenVFD, you can take a look here 1 Quote
Mark Waples Posted February 15, 2025 Author Posted February 15, 2025 Hi Both, thank you for the advice. Nick do I need root permissions on android to get my openvfd device tree settings as I do not have root? and just to confirm its /storage/.config/ and not /.storage/.config/ Kind regards, Mark 0 Quote
Nick A Posted February 15, 2025 Posted February 15, 2025 (edited) Good question. I'm not sure. First you need to enable Developer options. Then enable Wireless debugging on your device. https://www.androidpolice.com/use-wireless-adb-android-phone/ https://developer.android.com/tools/adb#Enabling If you are using linux you don't need Android SDK platform-tools to access adb software. sudo apt install adb sudo adb connect 192.168.X.X:5555 (x is your local network address for your android box) sudo adb shell ls -al /dev/block/ Edited February 15, 2025 by Nick A 0 Quote
Mark Waples Posted February 16, 2025 Author Posted February 16, 2025 22 hours ago, jock said: Not to hijack the thread, but there is a much better alternative driver rather than OpenVFD, you can take a look here Hi Jock, is it that easy - I couldn't see anywhere it says a T9MAX configuration file and regarding converting an existing vfd.conf file is a non-starter as I cannot even work out if I have one - it seems like I don't as openvfd is reading the device tree and I have no idea as to what the device tree file is and where it resides. Sorry - I am a complete noobie with Armbian/linux variants Meanwhile the display is flashing at me upside-down in a teasing sort of way!!! Kind regards, Mark 0 Quote
