suiramix Posted January 14, 2025 Posted January 14, 2025 Hi there, RK322A-box with R329Q v2.0 board, during the firmware upgrade [using Factory tool v 1.8] “Preparing IDB failed” occurred, most likely because that image file was wrong. The box is bricked, but boot up from SD card [multitool] and also connects to the PC… Next step: using RKAndroid Tool v 2.96 tried to restore the initial back-up image [the 14 files], but shows “U-boot file is larger than Flash size”…”ReadFlashInfo” detected the Flash Manufacturer: Micron, Flash size 0MB [?] and is disabled, see attached screenshoot: What is the next step fix this issue? Do I have to upload some RK loader.bin file ? P.S. the NAND is a SpecTek labeled PF I44 0 Quote
