How to install a higher version of kernel ?
Go to solution Solved by eselarm,
Yesterday I was doing an upgrade on my NanoPi T6, and then I got a kernel panic and no boot.
I am currently running kernel 6.1.84
To recover my information through a new mmc card I put armbian with kernel 6.12. And I logged in by doing a chroot.
There used to be an option to install a newer kernel via armbian-config, but I can't find that option now.
Is there any way how i can put on my current server a newer kernel or through cli which packages should i install.
Greetings,
A.H.
  • Solution
You could run:
sudo apt list | grep linux-image
Besides the vanilla Debian/Ubuntu ones, there are Armbian ones: vendor, current, edge
In your case your installed U-Boot might be incompatible with kernel 6.1.84, I had that for my Rock3A, I installed mainline U-Boot.
If you want all kernels, use http://beta.armbian.com in /etc/apt/sources.list.d/armbian.list
Or build yourself from source. The Armbian build runs fine on my NanoPi-R6C Armbian Bookworm
Edited by eselarm
@eselarm  Thanks for the idea. I'll test tonight.
Kernel 6.12 works apparently very well and that's why I want to put it in. ZFS also works well.
Apart from that, it made a positive impression on me that when booting the OS, the fan doesn't stop as it did with 6.1 and older versions and I had to manually adjust the dtb file.
