rin Posted yesterday at 02:11 PM Posted yesterday at 02:11 PM (edited) # uname -a Linux odroidc4 6.6.63-current-meson64 #1 SMP PREEMPT Fri Nov 22 14:38:37 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux Installed latest "Armbian_24.11.1_Odroidc4_noble_current_6.6.60-kisak.img" ...with latest sudo apt update; sudo apt upgrade, rebooted... Hardware: - Odroid-C4 - Sabrent USB 3.0 to 2.5-Inch SATA Adapter; Model: EC-SSHD with latest firmware patch, connected to a Kingston SSD: SA400S37480G # dmesg -l emerg,alert,crit,err [ 0.879290] meson-drm ff900000.vpu: DSI transceiver device is disabled [ 3.402246] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. [ 4.327154] panfrost ffe40000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found [ 4.871183] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. [ 5.093021] I/O error, dev sda, sector 2064 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2 [ 5.098203] I/O error, dev sda, sector 2088 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 2 [ 5.098226] I/O error, dev sda, sector 2120 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 2 [ 5.102570] Buffer I/O error on dev sda1, logical block 2, async page read [ 5.111428] Buffer I/O error on dev sda1, logical block 2, async page read I'm not worried about vpu, or panfrost errors, ..., since I don't care about gpu on this headless (non-desktop) cli mini-server. # dmesg | grep -i systemd-sysctl [ 3.331877] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 3.399999] systemd[1]: systemd-sysctl.service: Main process exited, code=exited, status=1/FAILURE [ 3.400501] systemd[1]: systemd-sysctl.service: Failed with result 'exit-code'. [ 3.402246] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. [ 4.822476] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 4.870046] systemd[1]: systemd-sysctl.service: Main process exited, code=exited, status=1/FAILURE [ 4.870601] systemd[1]: systemd-sysctl.service: Failed with result 'exit-code'. [ 4.871183] systemd[1]: Failed to start systemd-sysctl.service - Apply Kernel Variables. I checked /etc/sysctl.conf, and everything looks ok, afaik.? # cat /etc/sysctl.conf # # /etc/sysctl.conf - Configuration file for setting system variables # See /etc/sysctl.d/ for additional system variables. # See sysctl.conf (5) for information. # #kernel.domainname = example.com # Uncomment the following to stop low-level messages on console #kernel.printk = 3 4 1 3 ################################################################### # Functions previously found in netbase # # Uncomment the next two lines to enable Spoof protection (reverse-path filter) # Turn on Source Address Verification in all interfaces to # prevent some spoofing attacks #net.ipv4.conf.default.rp_filter=1 #net.ipv4.conf.all.rp_filter=1 # Uncomment the next line to enable TCP/IP SYN cookies # See http://lwn.net/Articles/277146/ # Note: This may impact IPv6 TCP sessions too #net.ipv4.tcp_syncookies=1 # Uncomment the next line to enable packet forwarding for IPv4 #net.ipv4.ip_forward=1 # Uncomment the next line to enable packet forwarding for IPv6 # Enabling this option disables Stateless Address Autoconfiguration # based on Router Advertisements for this host #net.ipv6.conf.all.forwarding=1 ################################################################### # Additional settings - these settings can improve the network # security of the host and prevent against some network attacks # including spoofing attacks and man in the middle attacks through # redirection. Some network environments, however, require that these # settings are disabled so review and enable them as needed. # # Do not accept ICMP redirects (prevent MITM attacks) #net.ipv4.conf.all.accept_redirects = 0 #net.ipv4.conf.default.accept_redirects = 0 # _or_ # Accept ICMP redirects only for gateways listed in our default # gateway list (enabled by default) # net.ipv4.conf.all.secure_redirects = 1 # # Do not send ICMP redirects (we are not a router) #net.ipv4.conf.all.send_redirects = 0 # # Log Martian Packets #net.ipv4.conf.all.log_martians = 1 # ################################################################### # Magic system request Key # 0=disable, 1=enable all, >1 bitmask of sysrq functions # See https://www.kernel.org/doc/html/latest/admin-guide/sysrq.html # for what other values do #kernel.sysrq=438 Swappiness for zram, see swapon vm.swappiness=100 # Decrease swap usage to a more reasonable level #vm.swappiness=30 # # Improve cache management #vm.vfs_cache_pressure=50 # # Improve writing to external media like USB memory sticks #vm.dirty_bytes=335544320 #vm.dirty_background_bytes=167772160 # ------------------------------- For the sake of brevity, I'm only running "transmission-daemon" on this successfully -sort of, with everything else being the default Armbian server settings, ... see: with: # cat /etc/udev/rules.d/99-usb-drive.rules ENV{ID_FS_UUID}=="501ce172-bc60-40db-90b6-9e025d2748bb", ACTION=="add", RUN{program}+="/usr/bin/systemd-mount --type=ext4 --no-block --collect $devnode /media/USB01/" ...so as to mount my USB-SSD-drive upon boot. But that's for another topic, since the "Failed to start systemd-sysctl.service - Apply Kernel Variables." were there before, and nothing else was changed. Basically, are the errors in my "dmesg" output above anything to really worry about.? Edited yesterday at 02:53 PM by rin fix some syntax again 0 Quote
