Since at least one week I find the system every morning with solid red led, waiting for a command in uboot.
When looking at the journal messages, the last messages are always:
Feb 10 23:45:01 etnas2 CRON[5176]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Feb 10 23:45:01 etnas2 CRON[5177]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Feb 10 23:45:01 etnas2 CRON[5176]: pam_unix(cron:session): session closed for user root
Feb 11 00:00:01 etnas2 CRON[5213]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Feb 11 00:00:01 etnas2 CRON[5212]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Feb 11 00:00:01 etnas2 CRON[5215]: (root) CMD (/usr/lib/armbian/armbian-apt-updates)
Feb 11 00:00:01 etnas2 CRON[5214]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
Feb 11 00:00:01 etnas2 CRON[5212]: pam_unix(cron:session): session closed for user root
Feb 11 00:00:03 etnas2 CRON[5213]: pam_unix(cron:session): session closed for user root
Feb 11 00:00:49 etnas2 systemd[1]: Starting dpkg-db-backup.service - Daily dpkg database backup service...
Feb 11 00:00:49 etnas2 systemd[1]: Starting logrotate.service - Rotate log files...
Feb 11 00:00:49 etnas2 systemd[1]: dpkg-db-backup.service: Deactivated successfully.
Feb 11 00:00:49 etnas2 systemd[1]: Finished dpkg-db-backup.service - Daily dpkg database backup service.
Feb 11 00:00:49 etnas2 armbian-ramlog[5278]: Tue Feb 11 12:00:49 AM CET 2025: Syncing logs to storage
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: sending incremental file list
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: ./
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: Xorg.0.log
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: Xorg.0.log.old
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: armbian-hardware-monitor.log
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: auth.log
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: boot.log
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: btmp
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: cron.log
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: kern.log
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: lastlog
Feb 11 00:00:49 etnas2 armbian-ramlog[5281]: syslog
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: user.log
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: wtmp
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: cups/access_log
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/lightdm.log
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/lightdm.log.old
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/seat0-greeter.log
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/seat0-greeter.log.old
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/x-0.log
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: lightdm/x-0.log.old
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: samba/log.nmbd
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: samba/log.smbd
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: sent 3,469,661 bytes  received 448 bytes  2,313,406.00 bytes/sec
Feb 11 00:00:50 etnas2 armbian-ramlog[5281]: total size is 4,794,812  speedup is 1.38
Feb 11 00:00:50 etnas2 systemd-journald[588]: Time spent on flushing to /var/log/journal/1141762e43884d8b9eb5d35b11be4daa is 55.926ms for 1057 entries.
Feb 11 00:00:50 etnas2 systemd-journald[588]: System Journal (/var/log/journal/1141762e43884d8b9eb5d35b11be4daa) is 17.4M, max 20.0M, 2.5M free.
Feb 11 00:00:50 etnas2 systemd-journald[588]: Received client request to flush runtime journal.
Feb 11 00:00:50 etnas2 systemd-journald[588]: Data hash table of /var/log/journal/1141762e43884d8b9eb5d35b11be4daa/system.journal has a fill level at 122.2 (5561 of 4551 items, 2621440 file size, 471 bytes per hash table item), suggesting rotation.
Feb 11 00:00:50 etnas2 systemd-journald[588]: /var/log/journal/1141762e43884d8b9eb5d35b11be4daa/system.journal: Journal header limits reached or header out-of-date, rotating.
After that no more messages, until the system gets booted again.   The issue seems similar to this post.  Power supply and system temperatures are fine, the system is running from EMMC memory so issues with  SD cards are ruled out.  When I boot off e.g. Jonathan Riek's Ubuntu 24.04 using the NVME drive, then all is fine: no nightly crashes.  I don't recall this issue when I installed Armbian 24.11.2 back in December, so possibly it came when I upgraded to 24.11.3 using `apt upgrade` (but could be wrong!)
I have added the cron job `*/1 * * * * /usr/bin/dmesg > $HOME/kernel-dmesg.txt` as suggested.
Looking at `/etc/cron.d` and more precisely `armbian-trunctate-log`, I see that `armbian-trunctate-logs` runs every 15 minutes, but it invokes `armbian-ramlog` in practice only just after mignight probably because `/var/log` is over 75% full.  Then `/usr/lib/armbian/armbian-truncate-logs` proceeds to synchronize (using `rsysnc`)  the logs files in zram (`/var/log`).
After that, the script calls `/usr/sbin/logrotate --force /etc/logrotate.conf` but this rotation takes place on `/var/log.hdd/`.
Somehow that does not sound right...  I would have thought it would be the other way around....
Finally, it just truncates the files in `/var/log`.   That could be dangerous as processes have these files open...  Logrotate sends a signal to processes to let them know they should reopen the log files.
armbianmonitor -u
Thanks in advance for any help.
