z28z34man Posted February 11 Posted February 11 I have an orange pi 3 LTS running armbian 25.2 noble gnome that i installed an xfce4 desktop i am trying to autostart a remmina RDP session when a user logs in. I started by making a .desktop file in file in the home/(xxx user name xxx).config/AutoStart and making it executable. the .desktop file will run fine when ran manually but doesn't start on boot I then tried making a .service file in /home/(xxx user name xxx)/.config/systemd/user/ then doing a systemctl --user daemon-reload then doing a systemctl --user enable (my service name) when i do a systemctl --user start (my service name) it runs fine on reboot it fails and when i check the status by systemctl --user status (my service name) it comes back failed with can not open display as the fault. what should I try next 0 Quote
Solution z28z34man Posted February 11 Author Solution Posted February 11 never mind I started messing with options in my .desktop file an was able to get it to work. 0 Quote
helotbc Posted 5 hours ago Posted 5 hours ago Please share your .desktop file... with sensitive information redacted. 1 Quote
