Holgi Posted February 28, 2025 Posted February 28, 2025 (edited) Hi, Today I updated to Armbian v25.2 and did the good old reboot after the update. I never had issue with runing the SBC headless, but since the update I get a blinking blue status LED for a couple of minutes until the system boots. When I tried to plug in a monitor to get an idea what is going on, the SBC boots normally. Monitoring with HDMI monitor plugged in: https://paste.next.armbian.com/ehirazemot Monitoring without HDMI monitor plugged in: https://paste.next.armbian.com/zaqipatoci Most notable difference are: [ 105.189528] meson-drm ff900000.vpu: [drm] *ERROR* flip_done timed out [ 105.189543] meson-drm ff900000.vpu: [drm] *ERROR* [CRTC:43:meson_crtc] commit wait timed out [ 115.429535] meson-drm ff900000.vpu: [drm] *ERROR* flip_done timed out [ 115.429544] meson-drm ff900000.vpu: [drm] *ERROR* [CONNECTOR:33:Composite-1] commit wait timed out [ 125.669535] meson-drm ff900000.vpu: [drm] *ERROR* flip_done timed out [ 125.669544] meson-drm ff900000.vpu: [drm] *ERROR* [PLANE:37:meson_primary_plane] commit wait timed out Do you guys have any idea how to fix this? Edited February 28, 2025 by Holgi 0 Quote
JFPman Posted March 4, 2025 Posted March 4, 2025 Hi, I estimated a similar behaviour after upgrading to 25.2.2: the box seemingly didn't start headless anymore., i.e. it was not reacheable remotely. My guess is that the absence of a HDMI connected screen during boot process lead to problems initializing the network ... maybe Connecting a monitor solved the boot problem. So I tried the use of a HDMI dummy plug which is working fine: the box is reacheable via network as expected. Regards, Joe 0 Quote
Holgi Posted March 4, 2025 Author Posted March 4, 2025 My network configuration also got mangled in the update, yet I was able to fix it by essentially redoing it from scratch and setting the correct permissions. This seems to be unrelated to the HDMI issue slowing down booting. I googled a bit more and found this mailing list conversation discussing an issue which seems to be fairly similar if not identical: https://patchwork.kernel.org/project/linux-clk/patch/20250213221702.606-1-linux@martijnvandeventer.nl/ Patching and compiling the kernel myself is something I don't trust myself doing. As I'm rarely rebooting my system, I'm currently accepting the long boot times. 0 Quote
