Cesar Da Silva Posted August 27, 2017 Posted August 27, 2017 Hi! I am trying to setup a 3 node galera cluster and have installed the following packages: mariadb-client/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 all [installed] mariadb-client-10.0/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 armhf [installed,automatic] mariadb-client-core-10.0/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 armhf[installed,automatic] mariadb-common/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 all [installed,automatic] mariadb-server/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 all [installed] mariadb-server-10.0/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 armhf [installed,automatic] mariadb-server-core-10.0/xenial-security,xenial-updates,now 10.0.31-0ubuntu0.16.04.2 armhf [installed,automatic] galera-3/xenial,now 25.3.14-1 armhf [installed] I have created a galera.cnf file which I put in /etc/mysql/conf.d/. Here is my current galera.cnf file: [mysqld] #mysql settings binlog_format=ROW default-storage-engine=innodb innodb_autoinc_lock_mode=2 innodb_doublewrite=1 query_cache_size=0 query_cache_type=0 innodb_flush_log_at_trx_commit=0 innodb_buffer_pool_size=256M bind-address=192.168.1.101 # # * Galera-related settings # [galera] wsrep_on=ON wsrep_provider=/usr/lib/libgalera_smm.so binlog_format=ROW innodb_autoinc_lock_mode=2 innodb_locks_unsafe_for_binlog=1 query_cache_size=0 query_cache_type=0 default_storage_engine=InnoDB innodb_log_file_size=100M innodb_file_per_table innodb_flush_log_at_trx_commit=1 wsrep_cluster_address="gcomm://192.168.1.8,192.168.1.9,192.168.1.101" wsrep_cluster_name='galera' wsrep_node_address='192.168.1.101' wsrep_node_name='node01' #wsrep_sst_method=xtrabackup-2 wsrep_sst_method=rsync wsrep_sst_auth=galera:PASSWORD I have the first node on an VM machine running on a PC, and start it with the command "galera_new_cluster" without any issue. But the node running the following kernel Linux web01.dasilva.network 3.4.113-sun8i #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017 armv7l armv7l armv7l GNU/Linux and the following distribution: DISTRIB_ID=Ubuntu DISTRIB_RELEASE=16.04 DISTRIB_CODENAME=xenial DISTRIB_DESCRIPTION="Ubuntu 16.04.3 LTS" Does not want to start as a node of the galera cluster. He does not even run the galera configuration according to the log. I also have tried to change the file permissin to 777 for the galera.cnf file. Here is the relevant log entries: Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] /usr/sbin/mysqld (mysqld 10.0.31-MariaDB-0ubuntu0.16.04.2) starting as process 1241 ... Aug 27 15:18:50 web01 mysqld: /usr/sbin/mysqld: Query cache is disabled (resize or similar command in progress); repeat this command later Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Using mutexes to ref count buffer pool pages Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: The InnoDB memory heap is disabled Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Compressed tables use zlib 1.2.8 Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Using Linux native AIO Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Not using CPU crc32 instructions Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Initializing buffer pool, size = 256.0M Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Completed initialization of buffer pool Aug 27 15:18:50 web01 mysqld: 170827 15:18:50 [Note] InnoDB: Highest supported file format is Barracuda. Aug 27 15:18:51 web01 mysqld: 170827 15:18:51 [Note] InnoDB: 128 rollback segment(s) are active. Aug 27 15:18:51 web01 mysqld: 170827 15:18:51 [Note] InnoDB: Waiting for purge to start Aug 27 15:18:51 web01 mysqld: 170827 15:18:51 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.36-82.0 started; log sequence number 1617103 Aug 27 15:18:51 web01 mysqld: 170827 15:18:51 [Note] Plugin 'FEEDBACK' is disabled. Aug 27 15:18:51 web01 mysqld: 170827 15:18:51 [Note] Server socket created on IP: '192.168.1.101'. Aug 27 15:18:51 web01 mysqld: 170827 15:18:51 [Note] /usr/sbin/mysqld: ready for connections. Aug 27 15:18:51 web01 mysqld: Version: '10.0.31-MariaDB-0ubuntu0.16.04.2' socket: '/var/run/mysqld/mysqld.sock' port: 3306 Ubuntu 16.04 Any suggestions on how to make this work? Regards, Cesar da Silva
