geka Posted December 13, 2015 Posted December 13, 2015 Hy,I use Cubietruck / ArmbianI have a problem with I2C connecting to an Arduino.my Python program returns me an error when I use the SMBus module : read_byte_data the function (address, reg) bug while writing functions work well. here is my Arduino code : #include <Wire.h> #include <LiquidCrystal.h> #include <string.h> #include <ctype.h> const int RS = 12; const int E = 11; const int D4 = 5; const int D5 = 4; const int D6 = 3; const int D7 = 2; LiquidCrystal lcd(RS,E,D4,D5,D6,D7); #define SLAVE_ADDRESS 0x12 byte regs[3]; int regIndex=0; byte lastExecReq = 0x00; char message[20]; void setup (void){ regs[0] = 0x00; regs[1] = 0x00; regs[2] = 0x00; Wire.begin(SLAVE_ADDRESS); Wire.onReceive(receiveEvent); Wire.onRequest(requestEvent); Serial.begin(9600); lcd.begin(20,4); lcd.print ("LCD OK"); sprintf(message,"Bus I2C 0x%02x Ready",SLAVE_ADDRESS); Serial.println(message); lcd.setCursor(0,1); lcd.print(message); } void loop(void){ if (regs[0]==0x00){ delay(100); return; } switch(regs[0]){ case 0x01 : break; case 0x02 : break; case 0x03 : if (regs[1]>0){ lcd.setCursor(0,2); lcd.print("Start ... "); }else{ lcd.setCursor(0,2); lcd.print("Stop ... "); } break; } } void receiveEvent(int byteCount){ int byteCounter = 0; while (byteCounter<byteCount){ byte b = Wire.read(); byteCounter +=1; if (byteCounter == 1){ regIndex = b; } else{ switch(regIndex){ case 0 : regs[0] = b; lastExecReq = b; break; case 1: regs[1]=b; break; case 2: regs[2]=b; break; } } } } void requestEvent(){ switch(regIndex){ case 0x00: switch (lastExecReq){ case 0x01: Wire.write(0x03); break; case 0x02: Wire.write(regs[1]+regs[2]); break; default : Wire.write(0xFF); } break; default: Wire.write(0xFF); } } and here Python #!/usr/bin/python import re import smbus import time address = 0x12 class Bus_I2C(object): def __init__(self,address,busnum=1,debug=False): self.address = address self.bus = smbus.SMBus(busnum) self.debug = debug def errMsg(self): print("access error 0x%02X: check your I2C address")%self.address return -1 def write8(self,reg,value): try: self.bus.write_byte_data(self.address,reg,value) if self.debug : print("I2C : write 0x%02X in the reg 0x%02X")%(value,reg) except IOError,err: return self.errMsg() def writeList(self,reg,list): try: if self.debug: print("I2C : write a list in the reg 0x%02X:")%reg print(list) self.bus.write_i2c_block_data(self.address,reg,list) except IOError,err: return self.errMsg() def readU8(self,reg): try: result=self.bus.read_byte_data(self.address,reg) #result=self.bus.read_byte(self.address,reg) if self.debug: print("I2C : device 0x%02X returned 0x%02X from reg 0x%02X")%(self.address,result,reg) return result except IOError,err: return self.errMsg() i2c = Bus_I2C(address,1,True) print("///////////// 0x01 in reg 0") i2c.write8(0,0x01) time.sleep(0.200) print("///////////// read reg ...") print(i2c.readU8(0x00)) time.sleep(0.100) print("///////////// start LCD ...") i2c.write8(0x01,1) time.sleep(0.02) i2c.write8(0x00,0x03) time.sleep(0.100) time.sleep(5) print("///////////// stop LCD ...") i2c.write8(0x01,0) time.sleep(0.02) i2c.write8(0x00,0x03) time.sleep(0.100) where is the bug ? thank for your help geka
