How to get rid of "Unable to open SPI device: No such file or directory" message?
Hi everyone. I have an Orange Pi Zero.
1. I installed legacy kernel to my SD card (downloaded from https://www.armbian.com/orange-pi-zero/ )
2. I made updates & upgrades. Afterwards, I downloaded WiringOP-Zero from https://github.com/xpertsavenue/WiringOP-Zero
3. Now here comes to problematic part.  I checked my files as
ls -aol /dev/spi*
and could see spidev0.0 and spidev1.0.
Then I wrote a test program for my SPI pins (MOSI-MISO-CLK), I can compile the program but whenever I try to use spidev1.0 I get this error below :
Eventhough spidev0.0 works fine.  Can someone help me 'bout it? Basicly it is "how to enable spidev1.0" my question.
which version of OS you are using? because i am facing same problem in 5.38.
do you get any solution? then please share with me because i am stuck on that.
