danfoxley Posted March 8 Posted March 8 (edited) Armbianmonitor: https://paste.armbian.com/xayodaqowe Can anyone point me in the right direction for an Armbian image that would allow audio recording over the 3.5mm jack? I'm trying to record audio over the 3.5mm jack. This works on a previous installation, but I'm trying to update to a curreent Armbian. Running Tinkerboard S R2.0 and this image: Armbian_25.2.1_Tinkerboard_noble_current_6.12.13_xfce_desktop.img Playback works record does not. Works: aplay /usr/share/sounds/alsa/Side_Right.wav -D hw:CARD=Audio,DEV=2 None of the following arecord commands work: arecord --vumeter=mono -D hw:CARD=Audio,DEV=0 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D hw:CARD=Audio,DEV=1 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D plughw:CARD=Audio,DEV=0 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D plughw:CARD=Audio,DEV=1 -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D default:CARD=Audio -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D sysdefault:CARD=Audio -f S16_LE -c 2 -d 5 /tmp/t.wav arecord --vumeter=mono -D front:CARD=Audio,DEV=0 -f S16_LE -c 2 -d 5 /tmp/t.wav Edited March 8 by danfoxley clarification 0 Quote
Solution IBV Posted March 8 Solution Posted March 8 Hi, could it be that the mic is muted or volume is too low? You might check the situation with alsamixer (then F4 for capture controls). 0 Quote
danfoxley Posted March 8 Author Posted March 8 (edited) Thanks! That was the issue. alsamixer > F4: Volume was low/off and Capture was not enabled (SPACEBar). Hitting the spacebar with the channel selected put the red text "CAPTURE". Edited March 8 by danfoxley 1 Quote
danfoxley Posted 12 hours ago Author Posted 12 hours ago On 3/7/2025 at 7:03 PM, danfoxley said: Playback works record does not. Works: aplay /usr/share/sounds/alsa/Side_Right.wav -D hw:CARD=Audio,DEV=2 Correction to original post, I have typo and did not put in "plug" for plughw. aplay /usr/share/sounds/alsa/Side_Right.wav -D plughw:CARD=Audio,DEV=2 1 Quote
