alansrobotlab Posted March 9, 2025 Posted March 9, 2025 I'm unable to activate bluetooth in the armbian build above. Confirmed bluetooth working in the vendor radxa bookworm xfce build. Here's what I see in dmesg that may be relevant: ... [ 9.329177] kernel: Bluetooth: Core ver 2.22 [ 9.329247] kernel: NET: Registered PF_BLUETOOTH protocol family [ 9.329261] kernel: Bluetooth: HCI device and connection manager initialized [ 9.329281] kernel: Bluetooth: HCI socket layer initialized [ 9.329296] kernel: Bluetooth: L2CAP socket layer initialized [ 9.329337] kernel: Bluetooth: SCO socket layer initialized ... [ 11.165207] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77. [ 11.165235] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 17. [ 11.165248] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 12. [ 11.165261] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 11. [ 11.165269] kernel: [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!. [ 11.165326] kernel: [BT_RFKILL]: Request irq for bt wakeup host [ 11.165815] kernel: [BT_RFKILL]: ** disable irq [ 11.165979] kernel: [BT_RFKILL]: bt shut off power [ 11.166001] kernel: [BT_RFKILL]: bt_default device registered. [ 11.166198] kernel: input: bt-powerkey as /devices/platform/wireless-bluetooth/input/input2 ... 0 Quote
alansrobotlab Posted March 9, 2025 Author Posted March 9, 2025 I found a thread over at dietpi that talks about radxa zero 3w hardware rev with a different bluetooth controller. https://dietpi.com/forum/t/radxa-zero-3w-bluetooth-not-working/20555/11 Can confirm that I have the same bluetooth module listed in dmesg spot@radxa-zero3:~$ dmesg | grep -i aic8800 [ 18.041504] AICWFDBG(LOGINFO) aicwf_sdio_chipmatch USE AIC8800D80 [ 18.058640] rwnx_load_firmware :firmware path = /lib/firmware/aic8800/SDIO/aic8800D80//fw_patch_table_8800d80_u02.bin [ 18.075178] rwnx_load_firmware :firmware path = /lib/firmware/aic8800/SDIO/aic8800D80//fw_adid_8800d80_u02.bin [ 18.082304] rwnx_load_firmware :firmware path = /lib/firmware/aic8800/SDIO/aic8800D80//fw_patch_8800d80_u02.bin [ 18.136946] rwnx_load_firmware :firmware path = /lib/firmware/aic8800/SDIO/aic8800D80//fmacfw_8800d80_u02.bin 0 Quote
Solution alansrobotlab Posted March 13, 2025 Author Solution Posted March 13, 2025 (edited) I feel dirty for solving it this way but I don't understand enough about the system to fix it properly. There's something goofy with the bluetooth controller in these chips and radxa works around it by resetting the UART connection with a service file that calls rsetup. You can manually fix/repair/start bluetooth with the following command but you need to run it once every time you reboot: https://forum.radxa.com/t/bluetooth-not-working-zero-3w-official-os/24072/5 hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep radxa has a service file that resets the bluetooth UART1 /dev/ttyS1 on boot. To get it installed you need to install librdui, rsetup, and rsetup-config-aic8800-ttys1 from the radxa githubs https://github.com/radxa-pkg/rsetup/releases/tag/latest https://github.com/radxa-pkg/librtui/releases/latest So the most current file links as of today are: https://github.com/radxa-pkg/librtui/releases/download/0.1.6/librtui_0.1.6_all.deb https://github.com/radxa-pkg/rsetup/releases/download/0.4.12/rsetup_0.4.12_all.deb https://github.com/radxa-pkg/rsetup/releases/download/0.4.12/rsetup-config-aic8800-ttys1_0.4.12_all.deb Then cd to wherever you download them to and run: sudo apt install ./librtui_0.1.6_all.deb sudo app install ./rsetup_0.4.12_all.deb sudo apt install ./rsetup-config-aic8800-ttys1_0.4.12_all.deb and reboot. then confirm with your tool of choice, or bluetoothctl: spot@radxa-zero3:~$ bluetoothctl hci0 new_settings: powered bondable ssp br/edr le secure-conn cis-central cis-peripheral Agent registered [CHG] Controller 98:03:CF:D2:2C:55 Pairable: yes [bluetooth]# exit spot@radxa-zero3:~$ Enjoy! Edited March 13, 2025 by alansrobotlab 0 Quote
yuki Orikasa Posted July 15, 2025 Posted July 15, 2025 Thank you for the solution!!! I struggled for days on this. 0 Quote
