Rob Tapp Posted March 13, 2025 Posted March 13, 2025 I have a NanoPi Neo. I am trying to get a gps module setup on it. Just at typical neo6m, serial gps module. I would like to start out at the basics. I am not new to linux, or micro controllers, but I am new to the nanopi. How can I confirm that something is talking on the serial ports? Is there a way to route the serial port traffic to the terminal when I am logged in through ssh? I am not sure the uart1 is enabled, but even if it is enabled, I really wouldnt know how to confirm it. Does anyone know where I can look to find some info? I would like to find out how to enable the serial ports for communication with another device & how to confirm that I have it enabled and confirm there is traffic coming in. Anyone have any ideas on where to I can look to find this, or does anyone know how? Rob 0 Quote
Solution IBV Posted March 13, 2025 Solution Posted March 13, 2025 Hi, take a look at this thread: The user is using picocom to check the traffic on ttyS2: picocom /dev/ttyS2 --baud 115200 --echo 0 Quote
Rob Tapp Posted March 13, 2025 Author Posted March 13, 2025 Hi. Thanks for the response. I will check it out. Is there any documentation on the armbianmonitor command? Robby 0 Quote
IBV Posted March 13, 2025 Posted March 13, 2025 To provide logs: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-provide-boot-logs-for-inspection There's also "armbianmonitor -h" which shows the possible options. 0 Quote
Rob Tapp Posted March 13, 2025 Author Posted March 13, 2025 Ok, I think I understand that part now. Thanks! 0 Quote
Rob Tapp Posted March 13, 2025 Author Posted March 13, 2025 Awesome! Thank you for the help. I was able to use the picomon to figure out that I needed to be wired to the uart0 to see the gps data coming in. Rob 1 Quote
