Guest Posted March 24, 2025 Posted March 24, 2025 (edited) It seems there are no any on-board wifi nodes (vcc33-wifi, vcc-wifi-io, wifi-pwrseq ) in sun50i-h618-orangepi-zero2w.dtb , and exists in Zero 3 dts . zero2w.dts: type_addr_wifi = <0x02>; zero3.dts: type_addr_wifi = <0x02>; zero3.dts: vcc33-wifi { zero3.dts: regulator-name = "vcc33-wifi"; zero3.dts: vcc-wifi-io { zero3.dts: regulator-name = "vcc-wifi-io"; zero3.dts: wifi-pwrseq { zero3.dts: reg_vcc33_wifi = "/vcc33-wifi"; zero3.dts: reg_vcc_wifi_io = "/vcc-wifi-io"; zero3.dts: wifi_pwrseq = "/wifi-pwrseq"; Edited March 24, 2025 by Guest Zero 2W, not Zero2 0 Quote
Guest Posted March 24, 2025 Posted March 24, 2025 use the old dtb file in 6.12.16, wifi works. please check the dts patchsets . 0 Quote
Guest Posted March 24, 2025 Posted March 24, 2025 Yes, you removed this patch in 6.13: - patches.armbian/arm64-dts-sun50i-h618-orangepi-zero2w-Add-missing-nodes.patch 0 Quote
