webbbn Posted September 5, 2017 Posted September 5, 2017 I installed the experimental version of the NanoPi Neo Air distribution on my Air a month or two ago. At the time I believe Bluetooth was not working on that version. I don't see any indication that it is not working now, but it doesn't seem to be working on my install. Is Bluetooth working on the experimental kernel? If so, should I just re-install, or is it not hard to get it working on an existing install? I just installed the latest updates and rebooted, and that didn't fix it. The symptom that I'm seeing is that if I run bluetoothctl it prints a prompt, but seems to lock up.
