7alken Posted April 11, 2025 Posted April 11, 2025 (edited) Armbianmonitor: https://paste.armbian.com/dukejeyele hi all, I was looking for some unified os for more "rpi zero" clones and found beautiful armbian; and I am quite new to linux still, longtime/decades windows user; to "dogfood", I am also considering use of armbian on my "tiny-big" uefi-x86 (now NUC10, but got now new amd ryzen7 8845hs gmktec nucbox k8 plus), so I tried as very first setup on that ryzen7 latest armbian "ubuntu gnome" - monitor output is attached, so far so good, although I dont know if everything around usb3/4 is working well (log contains some red messages, dont understand them) - it was only simple install, and I have this comments: https://www.gmktec.com/products/amd-ryzen-7-8845hs-mini-pc-nucbox-k8-plus usb-live boot was okay, I then executed armbian-config where in "storage" I proceeded with default installation (I didnt read well the instructions to run armbian-install in fact, this is not in set of icons after usb-live boot also...), which it seems selected nvme1 instead of nvme0 ??? (will try again with other variants as xfce again), so after this way of installation, reboot was into grub rescue, so I did it again forced to nvme0 (deleting all from nvme1 also by gparted) and the reboot was okay ... although, when I am powering-off linux from menu then nucbox pwr button green led switches off, BUT after removing usb and swiching on the nucbox by button nothing happens, black screen (long time, nothing) - I expected some longer boots because of DDR5 behavior (new to me too) but this is not the case. I must force OFF the nucbox by holding power button for 4secs and then re-powering on is okay ... this is not nice behavior 🙂 this nucbox K8 plus has very open APTIO BIOS, nothing is simplified and I left everything on auto for now, it seems secure boot is disabled and what surprised me too is that install to nvme storage did only MBR partitions, not GPT. hope its all handled well for offsets and blocksizes - are possible (good?) 4KB sectors for most efficient nvme flash ssd? I dont know if some defaults changes in bios can force armbian to defalt to GPT partitions, even if it is necessary. in windows, I have 2 big disks now and data/user are is only selected logically by virtuall drive letters (visualsubst), I use lots of them to separate areas and need this to mimic somehow in linux; its question if separate "user" partition with fixed size is okay too ... on windows, I do backups by onedrive syncing and by ZIPs to second drive and even to usb attached sata disks too and only for "really" user data, not everything the same way - its question if on linux its simpler to backup entire partitions (??) I was also quite surprised that "ubuntu gnome" variant boots only to some "tablet only?? ui" very simple ui without any menu, windows without minimize icons ... I am new to linux, what is this "style"? this is "unity" or some tablet variant selected by sone defaults? ... very weird for me, too simple, not useable as desktop, so I will try XFCE and KDE Neon too, sure ... When I tried to add language for regional date/time formats support , trying to download CZ (Czech) failed, probably some minor quirk too; I had no chance to test everything, but I was surprised that it during boot found the WIFI and installation was really deadly easy and sexy, despite that first default bad selection of nvme1 as target (I am not sure if I didnt it in fact .... will try again similar way) ... but what is shown in icons/apps set is contrary to some getting started doc pages, where is mentioned "armbian-install" (not necessary as armbian-config - storage did it too??), btw red config and configng icons launch the same script; I understand that this is lightweight setup and I in fact like it a lot, but that simplistic (tablet?) desktop was like something for kids )) so, thanks to all NicoD videos (I saw tens of them) as my primary intention to test faster "rpi zero" clones is to run some Sinclair QL emulator on them, something with SMSQE, ideally, somehow, there are variants of it; on windows, best/fastest is probably QPC2/SMSQE but this is not full emulation, its hybrid where interfacing to fast windows host is often accelerated on it, so this is not linux-aware emulator, and I cant imagine if it would be possible in wine, probably not; other emulators exists, one of them for SMSQE is based on java too - goal was simply to make some low-power portable Sinclair QL (with SMSQE) machine, so I need to select best/fastest "rpi zero" clone with working GPU acceleration for sure. https://www.kilgus.net/qpc/what/ youtube: yU0ptNyNqcI It is not yet clear if I will converty my main big machine to linux, but having one unified system for "everyhting arm" is definitely nice, it seems that armbian can be my primary linux distro even in virtual machines, I like the concept and systematic approach in documentation and development and even contribution, I read lot of docs and its very nice, it seems. So will be glad also to support you, as much as possible. Thanks, Petr Edited April 11, 2025 by 7alken 0 Quote
7alken Posted April 16, 2025 Author Posted April 16, 2025 (edited) hi, I tested also xfce on the system, have some notes to installation (also others available uefi-x86 images) and will continue here as armbian newbie describing experiences. for now, quick notes: grub config - tiny: would be nice to have here some most used items explicitly defined as help/doc too - mainly delay(?) ... as a newbie, will be easy to modify existing item than search for it boot - selecting locale - when I was finding CZ, it is in some images listed as 98, somewhere as 99 ... probably the list is not consistent (I dont know if it was goal, but having this list stable can be handy) - tiny quirk - some images miss board logo, debian images even miss armbian logo and there is debian 12 default, okay )) armbian-config - storage - install should have probably alphabetically sorted items, as in some case nvme1 is listed first and selected by default, better nvme0, of course 🙂 - also, it seems that in some images, desktop icon for this launches using sudo and elsewhere without it, some images failed storage-install from icon, by sudo from terminal, okay (I also realized that uefi-x86 has obviously drastically simple armbian-config vs arm sbc boards, sure ... had chatgpt involved in discussion what all to possible configure on armbian installed systems - if its possible to trust all what it replied, will see ... I am totally new to GPU related things like mesa, panfrost, wayland etc etc ... gpt is good source of comparison info, imho, I ued it as teacher available 24/7, expecting also invented halucinations, sure )) Xfce - gparted was unable to launch from menu?? dont know why yet I am making these notes here for myself also, can try to peek inside armbian-config sources soon to learn how things are done and try to solve it, if possible (few years ago I did my very first bash work related to John Winans Z80retro! as CP/M firmware change/backup toolkit for midnight commander, so far so good experience, bash is okay) cheers Petr Edited April 16, 2025 by 7alken 0 Quote
7alken Posted April 20, 2025 Author Posted April 20, 2025 hi, continuing test, now with updated/upgraded XFCE, latest stable kernel and usual NicoD mods of desktop to try them all in vertical deskbar https://paste.armbian.com/punucaniso everything works till now 0 Quote
