igagis Posted April 13, 2025 Posted April 13, 2025 Hi, I'm trying to run weston on Odroid XU4, but it does not start. Seems something is wrong with GPU drivers. I have installed "Armbian 25.2.1 Bookworm Minimal" image and then installed weston via apt. Then, trying to run the weston fails with error: Date: 2025-04-13 UTC [13:47:44.248] weston 10.0.1 https://wayland.freedesktop.org Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/ Build: 10.0.1 [13:47:44.249] Command line: weston [13:47:44.249] OS: Linux, 6.6.81-current-odroidxu4, #1 SMP PREEMPT Mon Dec 30 15:59:39 UTC 2024, armv7l [13:47:44.249] Flight recorder: enabled [13:47:44.249] Starting with no config file. [13:47:44.250] Output repaint window is 7 ms maximum. [13:47:44.250] Loading module '/usr/lib/arm-linux-gnueabihf/libweston-10/drm-backend.so' [13:47:44.265] initializing drm backend [13:47:44.265] Trying logind launcher... [13:47:44.280] logind: session control granted [13:47:44.290] using /dev/dri/card0 [13:47:44.291] DRM: supports atomic modesetting [13:47:44.291] DRM: supports GBM modifiers [13:47:44.291] DRM: supports picture aspect ratio [13:47:44.291] Loading module '/usr/lib/arm-linux-gnueabihf/libweston-10/gl-renderer.so' MESA-LOADER: failed to open exynos: /usr/lib/dri/exynos_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) failed to load driver: exynos MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) failed to load driver: zink MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) failed to load driver: kms_swrast MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) failed to load swrast driver [13:47:44.301] failed to initialize egl [13:47:44.302] fatal: failed to create compositor backend Internal warning: debug scope 'drm-backend' has not been destroyed. Runing weston in pixman mode with "weston --use-pixman" succeeds, but I need accelerated weston. Any idea how I can install the missing GPU drivers? 0 Quote
igagis Posted April 13, 2025 Author Posted April 13, 2025 (edited) Installing `libegl1` makes weston run, but GPU is not used, rendering is done via software mesa. Edited April 13, 2025 by igagis 0 Quote
